Question about Dryers
My dryer stops in middle of drying cycle then i have to go and turn it back on
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
DWSR483EAWW GE Dryer doesn't turn off when set to "Optimum Dry"
Does the timer advance to the end or does it stop advancing in the middle of the cycle?
If the unit does advance to the end on timed but it won't advance on auto, that means your cycling thermostat isn't triggering. First, make sure your vent is cleaned and the best way to do that is just run a cycle without the vent hose connected to the back of the dryer to see if things change. If your dryer still won't dry properly, then the cycling thermostat will need to be replaced because it's not cycling properly.
Try it on the timed cycle. If it doesn't advance, then you have a bad timer and the timer will need to be replaced.
The cycling thermostat is mounted to the front of the blower wheel housing.
Here is the timer if it is found bad.
Here is the cycling thermostat if it is bad.
Keep me posted!
Nov 30, 2012 | Dryers
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Mar 30, 2010 | Kenmore Dryers
Not drying properly.Also stpos in middle of cycle.
You may have a partial blockage in the vent due to lint buildup. Also, check the lint trap to be sure it is clear. To check the vent pipe you must pull the machine away from the wall so you can get behind it. then loosen the clamp holding the vent tube or hose to the back of the dryer. Using a flash light check the back end of the dryer and the entire tube plus check to see what is going on outdoors where the dryer vents to the out-of-doors
Feb 24, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Was drying a load and the dryer stopped in the middle of the cycle and wont turn back on
small white fuse at bottom back of dryer is in the nuetral circuit and may be faulty. if so repace it and the thermastat that beside it and may sure you have good air flow to the outside.
Jan 29, 2010 | Kenmore Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
