Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Mow rund fine for as few minutes and then shuts off. I have replaced the coil and problem still persist.
  • 718 Answers
My suggestion is to clean your carb and try again. Make sure there is no water in gas tank..
Posted on Aug 30, 2010
My Z445 turns over, but won't fire and start. home and mowed with it for about 1 1/2hours, parked it,shut it off. I went out later to mow some more and it turns over but does not fire. Any ideas ?
it could be a few things. test the safety switches. if they are good take the cover off of the engine. unplug the coil and test to see if it has fire. if it does it may be a bad coil
Mar 07, 2017 | Garden
It has been shutting down and it mows for a few minutes and shuts down. It shut down three or four times before I could finish. Could it have to do with the arm that engages the blades?
it could be. check all the connections be sure they are tight. maybe change the spark plug. it kind of sounds like the spark plug or coil is breaking down at high temperatures. or the fuel pump is getting clogged.
Jul 29, 2016 | Garden
Troy-Bilt Colt XP. Start engine and begin mowing and everything is fine. After a few swipes on the yard, 2-3 minutes, PTO shuts off. turn off and back on works shortly. PTO clutch getting hot???
electric pto clutches get HOT (not warm) for only a few reasons
(1) worn out friction disks inside
(2) foreign object(s) not allowing clutch to fully engage a good blast of high pressure air knocks out most stuff , if let go to long this leads to 1st reason
Jun 29, 2015 | Garden
Dv209aew/xaa therm
u may have a bad motor windings problem, usually will rund for about 25 minutes to an hour then shut off, wait an hour and can run again then shuts off ? also check ur venting inside machine and to the wall a build up can cause it to overheat and then shut down? u may have to remove cabinet to see inside condition? which thermostats did u change, u may have bad hi-lo limit and cycleling thermostat
Jul 28, 2014 | Samsung Dryers
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My compressor shuts off after a few minutes
Hello
One possibilty is the out side coils or condenser is dirty.And the unit is shutting down on high heat.
Try cleaning the outside coils with some simple green cleaner or even comet spray, then rinse with a hose.
May 27, 2010 | Frigidaire FAS296R2A Air Conditioner
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
