Question about Samsung HLN567W 56" Rear Projection HDTV
I have a six year old SAMSUNG HLN567W set & it has worked great, up till yesterday. When I tried to turn it on, nothing. Only the green TIMER LED blinks and only while the power on button is depressed, either with the remote or on the side of the set. No other lights illuminate and the screen remains black. Hope you can help diagnose the problem. Cheers from CANADA, - Mike
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Two things to try:
1) If you have not done so, remove the lamp this model uses and examine it to see if it is intact or shattered inside. Lifespan on lamp is about 2,000 hours.
2) If before set failed you heard a fan like or high pitched sound or even a grinding sound, you may have a bad color wheel.
The set will detect if the wheel is not turning and shut the lamp off in a few seconds. Color wheel turns at over 12,000 RPM and is a common failure part.
The lamp is customer replaceable and the color wheel
also can be---there are video instructions for this on You Tube.
Let me know if this was helpful, I attach a photo of the color wheel and can tell you how to examine it with the lamp removed.
SD TECH
Posted on Aug 30, 2010
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Samsung tv hln567w
This was a $4000 TV 5 years ago. I own one, and it is still a very good TV. The biggest thing that can go wrong (and is worth repairing) is the light bulb can go out & it costs about $200 to replace. If anything else major goes out, it is probable better replaced than repaired.
Feb 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Washing machine will not drain or spin
TO BAD ABOUT TIMER CANNOT RETURN DUE ELECTRICAL PARTS ,,, NOW REPL LID SWITCH THAT WILL FIX UR PROBLEM
Nov 22, 2008 | Washing Machines
Fuji F650 camera 1yr old. Worked great till the other day I went to turn it on the green light came on but nothing else happened. I recharged the battery but it still does not work. The green light will...
the battery is not holding charge anylonger.need to buy new one (aprox $9 on ebay) or try to have it rplaced atthe store you bought the camera from (it should last more than 1 year for sure)
Oct 02, 2008 | Cameras
Samsung HLN567W 56 in. Rear Projection HDTV...
could be two resistors on the power supply pannel.Check RS801 and RSF801 this will cause a dead set. Let me know if you need more help
Apr 06, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Samsung HLN567W 56" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
