Question about Dewalt DC011 AM/FM Radio
On off switch loose keeps turning off and on, have to wedge paper in it to make it stay on, can it be repaired?
  • buschboxer Mar 17, 2009
    Nothing happens when the on/off knob is turned, the display flashes for the time to be set, but no buttons work. Can I get replacement power switch?
  • 313 Answers
Its a bad volume control, when replacing the volume control you gonna have to uograde 2 other circuit board.economical for a max cost repair/garranted repair cost
Posted on May 27, 2008
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
I taking out my HP deskjet 3050 j610a out of the box as i have newly bought it. As i try to get the alignment page printed the screen just says printing and nothing happens. Then i switch it off and back...
This printer appears to be faulty, I suggest you return the printer to the supplier for a replacement or repair as it is under warranty. If you try to repair it yourself, you most likely void your warranty.
Aug 24, 2011 | HP LaserJet 3050 All-In-One Printer
My NV 3 keeps turning itself off and on, repeatedly, it stays on for about 20 seconds then shuts off
It sounds like you could easily have a loose battery. This is common in older phones, or phones that may be a little worn. Try these suggestions:
- Remove the back of the phone and clean the battery, compartment and contacts with a little alcohol and a lint-fee wipe. That way you know the battery has good contact with the phone.
- Replace the battery and hold it in firmly, does that fix the issue?
- If so, try wedging a folded piece of paper between the battery and outer case of the phone, or putting some tape firmly across the back of the phone (and around the sides) to compress the battery into place.
Mar 04, 2011 | LG enV VX9900 Cellular Phone
My n64 restarts every time i play it. sometimes 1 min into the game sometimes 30 mins into game play what would cause this
Well the software for the system is bad and it needs new processing software and it has a short in it then. Like a loose wire inside of the console.
Jun 13, 2010 | Nintendo 64 Console
My sony ericsson tm506 keeps shutting itself off when I turn it on. What should I do?
This phone suffers from a slightly loose battery. Wedge a small piece of very thin cardboard or paper in between where the battery and the phone (opposite the battery terminal end) so that the battery no longer has any wiggle room. This solved my issue with phone shut offs as well as others. Sony is having to replace the batteries on these phones hand over fist thinking it's battery issue, but it's really a fit issue.
Jun 06, 2010 | Sony Ericsson TM506 Cell Phone
The error light stays on
This is a problem with this printer. On mine it was because the pin on the right side did not fully contact the switch when the cover was closed. To remedy the problem I took a phillps screw driver and loosed the housing that has the pin molded into it. I then folded up a piece of paper many times and wedged it under the housing and walla the error message was fixed.
May 14, 2010 | Minolta magicolor 2400W Laser Printer
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
Vacuum turns itself off or won't turn on
Sounds like a bad on/off switch or a loose connection somewhere in the vacuum. If you can remove the switch, you can see if any connections are loose. The switch itself can be checked if taken out of the circuit and tested with a meter or a continuity light.
Otherwise, you might want to consider a repair shop.
Mar 29, 2009 | Kenmore Progressive Bagless Upright with...
Dewalt DC011 AM/FM Radio Logo
351 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
