Question about Fellowes 3011001 Shredder
Motor runs blades not turn
The shredder will run fine in Reverse. In forward, the motor runs, but the blades do not turn. Thanks for your help
  • 2 more comments
  • tyka May 19, 2008
    I have the same problem. Motor runs blades will not turn. Will work in reverse only.
  • Anonymous Feb 28, 2009
    "Motor runs blades not turn"
  • Anonymous Mar 17, 2014
    I have a SPL QW 120D shredder. Works very well; however when it was new, the shedder worked on what I term as "stand by"; convenient when you're sorting thorough paper documents. The shredder would be on , but the motor would not run unless you placed the paper in the opening. For some reason it does not work that way anymore. Although when I turn it on , it does work, and will run forward or backwards just fine. I have tried running back and forwards for several minutes in an attempt to clear any possible logged fragments, but no effect. I have not attempted to take it apart yet, but I would like some suggestions on how I approach repair this problem?
  • Anonymous Mar 23, 2014
    I have a Fellowes SB-95C shredder that just started malfunctioning. Motor turns the blades for about 3 seconds either forward or reverse and then stop turning. But the motor continues to run with a deep clunking sound. Cleaned everything out of the blades and oiled them, but still does the same thing. Any suggestions?
  • 3 Answers
Sorry about that, there is no gears for that machnie. Have a great day!
Posted on May 09, 2008
My shredder will not work. It makes sounds both forward and reverse, but the blades don't; turn. There's no jam signal. Help!!
Most likely one of the gears popped off or cracked. The blades are gear driven by a motor and it's pretty straight forward. If the blades aren't moving, then it's probably a gear problem since you said the motor runs.
Not much you can do without taking it apart.
Good luck. =)
Mar 10, 2015 | Shredder Office Equipment & Supplies
I have a royal shredder modle MP220 the motor is running but it doesn't will not pull the paper in . I cleaned it out and still nothing .
It is possible the blades are running in reverse. If the motor is running and the blades are turning without putting paper in, check the position of the switch. The motor should not turn on automatically when repositioning the switch. Reposition the switch so the light is on, but the motor does not run. Then try to put in paper. I hope this helps.
Apr 19, 2014 | Royal 160MX Shredder
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here:
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here:
May 25, 2010 | Royal 85X Shredder
It will not grab the paper; need to press forwared
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
Jun 19, 2009 | Fellowes PS60C-2 Shredder
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
Jun 01, 2009 | Office Equipment & Supplies
Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Mar 13, 2009 | Fellowes OD700C Shredder
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Fellowes 3011001 Shredder Logo
350 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
