Question about Singer 5050 Mechanical Sewing Machine
Singer 5050 won't zigzag stitch
I have an old Singer 5050 that I bought about 10 years ago and hasn't been used for quite some time until I got it out recently.  It will straight stitch just fine, but it won't zigzag stitch at all.  When I change the stitch width to any of the zigzag settings it just goes in a straight line.  My stitch length is not at zero, either.  What's the problem?
  • 1 more comment
  • Miss Holly May 09, 2008
    There's a flap on the top for a "pattern module," but I can't see any sort of finger.  I took it out and put it back in according to the manual instructions but it doesn't seem to have made a difference.  I'm not sure if that's the same thing you mean.
  • Anonymous Jan 05, 2009
    same thing going on with my Singer 5050, any luck?
  • Malloriel May 19, 2009
    The machine sews beautifully on the straight, but if any other setting is attempted then I get only the straight stitch. None of the zig-zags or pattern stitches are appearing in the fabric at all. I've fiddled with the settings and combinations of them, and even opened her up, but I don't see anything obvious that is preventing it from working properly.
  • Singer Master
  • 11,177 Answers
It probably needs a thorough cleaning and oiling. If it hasn't been used for quite some time, the old oil has turned to glue and is preventing the parts from moving like they should.
Usha janome magic stitch removal of right side cover
My brother lock 546D has seized what can do
My singer touch and sew is stuck can get it to go up and down twice and...
Posted on Oct 17, 2016
    New Friend:
I have this same issue with that same machine. Did you ever figure out what was wrong with it??
Posted on Oct 16, 2016
4 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Posted on Oct 17, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I have the Singer Touch Tronic 2001. I bought it used for $50. It has the manual and all the parts. However, the manual refers to lifting the top console to access the stitch width selector dial and to change the pattern selector discs. I cannot seem to lift this console up even the manual says that it is hinged for easy access to these parts. Can anyone describe how to lift the console up? Or send a picture or video of this process?
Most appreciated!
Posted on Aug 09, 2010
Handwheel all of a sudden froze up. singer 1120
Check to be sure there are no threads caught in the hook area that may be preventing the machine from working. Short of finding some obstructions, it probably needs service even if it hasn't been used. May or may not be reparable.
Feb 12, 2016 | Singer Sewing Machines
Singer 306k manual
you can try the company at this link singerco com
Oct 28, 2017 | Sewing Machines
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
I just bought a Singer Golden Touch & Sew at an estate sale. The straight stitch works great but it will not do a true zig-zag. It starts at wide width and the zig-zag narrows steadily for about one...
Go to www.singerco.com and under customer support, you can download a free copy of your manual. Save it to your computer, then enlarge the diagrams, it is so much easier to see the details. The machine is a little more complicated than we are used to. It will also teach you how to lubricate and clean this little beauty. Good luck, have fun. Happy New Year.
Jan 01, 2011 | Singer 5050 Mechanical Sewing Machine
I bought a 5050 model on ebay and the handwheel is
Unless you want to deal with the little screws to take it apart, you may take it to an authorized singer service dealer. Look in your local yellow pages under sewing machines.
Apr 08, 2010 | Singer 5050 Mechanical Sewing Machine
I have a Quantum XL-1 that apparently has a broken timing belt.
I have an Quantum XL 1000 Singer Sewing machine that needs a throat plate. I am in need to find this piece. Please can you help?
Jun 10, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 5050 Mechanical Sewing Machine Logo
709 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
