Question about 350 HV ESP Security System 350HV ESP
I need to program the alarm to double pulse to unlock for toyota tacoma but i dont have the manual. it only unlock the drivers door. i need everyone to open. thank you. the alarm is the old one not the new.
3 Suggested Answers
  • 13 Answers
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Posted on Dec 04, 2008
sonicboomele
  • 1557 Answers
SOURCE: i need the wirirng directions for the viperxv car
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngmoz-screenshot-3.pngmoz-screenshot-4.pnghttp://forum.ecoustics.com/bbs/messages/4/207788.jpg
click on this link
very big install job good luck
need anymore help feel free to email me
sonicboomelectronics@hotmail.com
please rate this repair thanks
Posted on Aug 03, 2010
My 2001 toyota Tacoma won't start. I was cleaning
Try putting the key in the driver door lock and turning from lock to unlock. That should dissable the factory alarm system. You may have to do it a few times before it works.
Dec 04, 2012 | Cars & Trucks
Cant turn my alarm off and truck wont start
You need to use the main regular key. Not keyless remote... LOCK THE VECHELE DRIVER DOOR WITH KEY, THEN UNLOCK DRIVER DOOR WITH KEY. Once you have done this place key in ignition try to start car, and security problem should be resolved.
Aug 04, 2011 | 1999 Toyota Tacoma PreRunner
I bought a used car toyota camry 2005 and it has avital key less remote system installed. model is 474L. It has remote start working and drive door open/close However, i am not able to open the power...
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
May 05, 2011 | 474L TX 4-Button Replacement TX Remote
I have a 2008 toyota tacoma Prerunner. when I use the alarm remote to lock the doors, all doors close except the front driver side. I also noticed that no sound is made when i arm or disarm the alarm. ...
Hello! There is a Technical Service Bulletin # EL009-07 that addresses programing the door lock remote...Your dealer should have a copy...I mention the TSB up front as a possible solution to the problem...However I believe the drivers side Door Lock Assembly is defective or the wiring to the switch/motor is open...The assembly has a 4 pin connector...White/Red and White/Black are the switch contacts... Blue/Black and Blue/Red are the lock drive motor...If you have the expertise, gain access to the assembly and inspect the connector and test with a multimeter...If you are not comfortable doing that I would replace the assembly...
Guru............Saailer
Feb 01, 2011 | 2008 Toyota Tacoma
Only one door unlocks? Viper 5701.
The problem isnt with the alarm, it is probably with the tech that installed it. If the doors all unlock after pressing the unlock but many times in a row then that means that the tech has to program double pulse unlock in the features menu. If it still only unlocks one door then he must have gone to the wrong wire for the doorlocks.
Dec 29, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
After disconnecting the battery and then reconnecting it on my 2000 Toyota Tacoma, the alarm goes off and the car will not start. I do not have a remote for this car and need help in a course of action. I...
If after unlocking the driver door with the key and still no luck, put the key in the ignition and turn forward to start (if it won't start turn forward anyway) then push you're red reset button on the dash. That should do it.
Jul 10, 2009 | 2001 Toyota Tundra
Program my remote
Program your factory keyless entry functions
For 2001+ Tacomas equipped with a factory alarm or keyless entrymag-glass_10x10.gif, here are some programming options that allow you to adjust the way your locks work.
The first programming option allows you to set the entry unlock to: (A) unlock the driver door with one push, and the remaining doors with a second push OR (B) unlock all of the doors with a single push.
  • Open the driver's door. Remove the key from the ignition switch.
  • (Complete these steps within 40 seconds)
    1. Insert the key into and remove it from the ignition switch 2 times.
      (IN - OUT - IN - OUT)
    2. Close, then open the driver's door 2 times.
      (SHUT - OPEN - SHUT - OPEN)
    3. Insert the key into and remove it from the ignition switch 1 time.
      (IN - OUT)
    4. Close, then open the driver's door 2 times.
    5. Insert the key into the ignition switch and leave it in.
    6. Close the driver's door.
    7. Turn the key from LOCK to ON 4 times, ending at LOCK
      (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
    8. Wait for the locks to stop, then remove the key from the ignition switch.
  • On the key fob, press and release both LOCK and UNLOCK buttons at the same time.
    1. [For all doors unlock] press and release the UNLOCK button.
    2. [For driver door unlock] press and release the LOCK button.
  • Open the driver's door. The programming is complete. If programming did not occur, start over.
Jan 13, 2009 | 2001 Toyota Tacoma
350 HV ESP Security System  350HV   ESP Logo
355 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
