Question about Phoenix Digital PD-397 Car Amp
The surge protection light is on pd 396 what do i do
Should the interex surge protector have both red and green light?
the red may indicate a surge controlled but will no longer protect the equipment
most surge protection is only good for one hit and that fails the protection for more surges
read the user manual on it or go to a retailer and read the instructions on a new unit
Oct 25, 2016 | Televison & Video
I have an isobar 8. The line light comes on but the protection light does not and the plugs do not work. Any suggestions?
From your owners manual
"PROTECTED" or "PROTECTION
PRESENT" LED (Available on Select
Models Only):
Indicates the surge suppression components are intact and
providing complete protection against surges. If this LED does not illuminate,
some of the surge suppression components are not functioning, and the unit
should be replaced. Call Tripp Lite Customer Support at (773) 869-1234.
Oct 07, 2014 | Computers & Internet
I had a power outage & now my pc won't turn on.
It is possible that either the power supply or the motherboard is faulty.
Try swapping out the power supply (borrow one if you can) and if the PC power LED does not light up or the PC boot up, then you need a new PC.
I suggest you get a surge protection power board and connect your new computer to this surge protection power board. It will protect your computer from power surge problems.
Mar 31, 2011 | HP Computers & Internet
Had a storm lightening struck something lights went out came back on but router dosnt have solid green light just flashing orange light modem dosnt see the router but if i plug in to laptop bypassing...
It appears lightening has damaged your router. Do you have a surge protected powerboard and do you plug all your computer equipment into this powerboard?
If you do not have a surge protection board, I suggest you install one to protect your equipment.
Aug 05, 2010 | Belkin (F5D7230-4) Router (587009)
I have an Yamaha RXV440. It goes into protection mode instantly.
The Yamaha repair shop evidently couldn't find the failed component(s) and/or cold solder joints causing it to go into protection mode. Sony equipment has similar problems related to protection mode.
Mar 21, 2017 | Yamaha RX-V440 Receiver
I get a po440 and a po440 pd code
evap emission control system malfunction, po440
Jun 23, 2009 | 1998 Chevrolet Malibu
Amp on "protect" mode
Hi, what you need to do is unplug all the connections to the amp. The amp goes into protection when the circuitry over heats.\
First decrease all your gains to minimal volume.
Connect your 12+V, remote, and ground.
See if the protection light comes on then.
Next plug in your RCA cables.
Check protection light.
Then plug in your subwoofer cables.
See if you are still in protect mode.
Hopefully everything works alright again.
Just slowly increase the gain to see what the cut-off is. Make sure you aren't dropping the ohmage too low on the amplifier. Check manual for correct wiring and such.
Feb 08, 2009 | Phoenix Digital PD-394 Car Amp
Red light on surge protector
Yes i think it is, I think the red light just means that it is surge protected, My ones red light is on constantly to.
Sep 16, 2008 | Home Security
Phoenix Digital PD-397 Car Amp Logo
35 people viewed this question
Top Phoenix Digital Car Audio & Video Experts
xxxxxx xxx
Are you a Phoenix Digital Car Audio and Video Expert? Answer questions, earn points and help others
