Question about Tiny Computers B1996 19" CRT Monitor
What does the bip sounds sounds mean on my pc
Hi, need help, my pc powers up, give one long up bip and a long down bip, red and ligth on pc stays on, fans run high, but nothing on screen, can you tell me what you think the problem is, thanx
  • Franklin Ramsey May 11, 2010
    What type/model of computer is this? Depending on the type/model it could be a bad motherboard, cpu, memory, video card, or something could just be inproperly plugged into the motherboard.
    Guru:
  • 859 Answers
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
Posted on May 11, 2008
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
When I try to switch it on you can hear the processor go on but nothing happens, the screen stays black and then a very loud bip.....bip...bip occurs; and then..nothing else
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 20, 2010 | HP Compaq Presario V2000 Notebook
Tv power on and sutdown after a series of bips the green light change to red and stay red
Tv power on and sutdown after a series of bips Problem with the Daewoo DSJ-6000LN 60 in. Rear Projection Television tv power on and sutdown after a series of bips the green light change to red and stay red
Jun 15, 2010 | Daewoo DSJ-6000LN 60" Rear Projection...
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Ok.. MY PROBLEM IS THAT I TURN ON MY PS3 AND IT MAKES THE SOUND BIP..THEN WITH NO VIDEO ON THE TV OR SOUNFD COMING ITS DOES 2 BIPS AND IT TURN OFF AGAIN,,I HAVE TRY TO LEAVE IT ON A COUPLE OF...
lets try a few things bronx,
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode.
then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
Good Luck!
Ruben
Jul 19, 2009 | Sony Playstation 3 (PS3) Console
Computer didn't start
The bip-bip sound means that a necessary input/output device is missing or not working. Go to dell.com/support enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Apr 29, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
My nec vt46 does not want to turn on
You need to check the manual. It will tell you at the rear what the different lights mean.
Apr 13, 2009 | NEC VT460 Multimedia Projector
Flashing ligth
Usually means the battery is not seated correctly or is not charging.
Jan 18, 2009 | Dell Inspiron 5100 Laptop
Open Questions:
Acer Virus Removal ' Remove Acer Virus - DataAlign ' Call +1888784-9316 Since those early days of laptop production, Acer has grown to offer devices in just about every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. While many consumers consider products made by companies like Dell or Sony to be at the higher end of the laptop spectrum, savvy consumers are beginning to realize that although they are priced competitively, support acer laptops do not lag behind in quality at all. As the company continues to grow, there is speculation that they may also enter the tablet and smartphone markets as well. For the all-round support of Acer customers, we have trained a team of highly skilled, certified engineers with excellent knowledge for all issues particularly faced with Acer products. Technical support is provided 24/7 every day on our toll free helpline called acer computer support number. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues All these issues can be resolved by our round the clock available highly experienced tech support team with dedication and professional attitude, contact acer support. Our services: Get all your queries, issues and complaints sorted out most efficiently and in the least time with most effective results that stay for the longest duration by contacting our Acer Support team members by calling on acer customer service. Contact our technical support team for any assistance regarding issues concerning Acer Products by acer product support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 20, 2018 | Acer Computers & Internet
See all Tiny Computers B1996 19" CRT Monitor Questions
Tiny Computers B1996 19" CRT Monitor Logo
185 people viewed this question
Top Tiny Computers Computers & Internet Experts
David Payne
David Payne
Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
