Question about Kenwood KAC-8104D Car Audio Amplifier
KAC 6202 has power but no sound. - Kenwood KAC-8104D Car Audio Amplifier
    Master:
  • 373 Answers
The bridge is burnt inside
Posted on Aug 30, 2010
3 Suggested Answers
  • 105 Answers
SOURCE: Kenwood KAC-6202 power
check all of your connections . Make sure you have a good solid ground
Posted on Jul 15, 2009
  • 269 Answers
SOURCE: where can i get a new kenwood speaker level input
Usually i would consult a radio installer company Like a Mom and pop store or Best Buy.
Posted on Jan 28, 2010
Not getting power
Pull the fuses and check them. Make sure that the wires have power. Battery power should always be on(12V) and the remote wire should have power only when you turn on the radio. Also check to make sure you have a good ground to chassis. If your wires have power and the amp's fuses are fine, then the amp's fried. At that point if it's not under warranty, open it up and see what you find. I may be a cold solder point that need re soldering or a burnt lead on the PCB board. Pay close attention at the power end of the amp, where you hook up your wires, check around there especially.
Sep 05, 2011 | Kenwood KAC-6202 Car Audio Amplifier
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
Where can i get a new kenwood speaker level input cable for my Kenwood KAC-6202
Jan 24, 2010 | Kenwood KAC-6202 Car Audio Amplifier
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
There is no power...to it...it happened when i was tightening the power wire
Hello warpartybmt,
Sounds like you shorted power to ground. Such a short most likely blew the power fuse.
You do not say whether you did the original install or if it was performed by an aftermarket audio shop. A normal amp installation usually includes a "primary" fuse located within a few inches of the battery positive (+) terminal. Look for a fuseholder close to the battery and check the fuse. Below is an image of one such fuseholder. Yours may look similar or it may be a "tube" with a glass fuse.
Hope this helps.
May 10, 2009 | Kenwood KAC-6202 Car Audio Amplifier
Bridging issues
There's no signal on the L- and R+ terminals.
If you're going to bridge both speakers on the amp, each speaker must have an impedance of 8 ohms (or more). If you're unsure of the impedance of the speakers, connect one speaker to each channel.
Let me know if you have any other questions.
Sep 19, 2008 | Kenwood KAC-6202 Car Audio Amplifier
Apr 20, 2007 | Kenwood KAC-6202 Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
235 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
