Hi there ive got a honeywell cm67 room stat which im trying to fit but not going to plan need help please
    Guru:
  • 587 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Aug 31, 2010
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
Honeywell CM67 hydronic heating. Our sleep and out of the house temperature is programmed at 17.5, our in-house temp is programmed for 20.5. Problem is the thermostat is staying fixed on 17.5 for the...
I would say get a professional person to deal with it. Could mean a new thermostat. Is it battery operated? maybe the battery is low . I would replace the battery and see if that works before spending more money.
Aug 25, 2017 | Honeywell Programmable Thermostat Heater
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
New honeywell stat fitted the weekend all works but the dial seems out of sinc, room temp 20, stat clicks at 10
Go to honeywell.com
Mar 21, 2010 | Honeywell Programmable Thermostat Heater
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
Mar 16, 2008 | Computers & Internet
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
