Question about Dewalt Chop Saw D28700
My Dewalt chopsaw is about 10 years old, and quit working.So I Took the brushes out and put them back in. It worked for a day, then it would hesitate, then it died. I tried new generic brushes,but the new springs were smaller in diameter and hard to get in and it would not start. Coincedents or or for sure the brushes.
    Guru:
  • 479 Answers
If you can get your hands on a continuity tester, do a continuity check from the plug through the flex ,the switch, armature and back to the plug .It should be possible by a process of elimination to discover where the break is in the circuit.
It might be simply that there is a break in the cable where it exits the mains plug or where it enters the chop saw
Posted on Sep 04, 2010
I had a power outage. control board is blinking 1 blue light on the freezer side. Bulb works inside. nothing works
Lilly Spence... hello,
There is several quite obscure "things" that could have happened to your refrigerator...
Presuming OWNERS MANUAL "RESET" failed.
I can only talk in GLOBAL/TYPICAL terms without your make & model number... If you don't mind spending a wad of money and learning nothing in the process... you need only find a competent repair person... they will pluck off the bottom grill ... pop out the "black box" with your PCB (printed circuit board)... here-in-after
we will call that your "power control board" and either find that bad solder joint... or discover the board resident relay or transformer DID NOT SURVIVE...
On my refrigerator 22 year old AMANA (which I love) that part has become quite rare (just because of time... but there are repair services that can refurbish OLD packs (10 days end to end & $100 - $200 later)
BUT THE NEWER, SMARTER... high end refrigerators
have a real "Power CONTROL BOARD" typically under the frig (above the defrost tray... It is, in fact, one of the EASIEST replacement parts to perform on the REFRIGERATORS...
of today.
On my refrigerator 22 year old AMANA (SBDE20S4SW which I love) that part has become quite rare (just because of time... but there are repair services that can refurbish OLD packs (10 days end to end & $100 - $200 later)... I fund one on eBay ... $195.
TURNED OFF THE BREAKER...
CIRCUIT BOARD 12106802: Replacement fiasco:
- Wiggled out the defrost tray (took pictures with my camera)
- Unplugged the door (control panel) wires from front (took pictures with my camera)
- Took out the one ***** hold box up... and slid it (wires & all) out to work on.
- Removed one top ***** & removed box cover (a lot of wires = lots more USABLE pictures!!)
- Changed the board... (TURNED CIRCUIT BREAKER ON) worked fine...!!
- Found my bad solder joint repaired/replaced it ... (TURNED CIRCUIT BREAKER OFF/ON)
- Put old board back in...
(control lights flashing... refrigerator NOT working).
(BREAKER off)
- Took CLOSE look at pictures (found red/white transformer CONNECTORs EXACTLY WRONG... (fixed)
(BREAKER ON)... Works great!
Have spare (12106802 PCB)... Plan on keeping it forever.
Story moral: $195 later (I didn't need to spend)...
Happy happy happy.
You can make yourself prouder.
PLEASE NOTE...
The "BREAKER" ... I never recommend touching ANY electronics without STATIC (ESD) protection.
A tiny (teeniest) static discharge around the MOST ROBUST electronics can destroy it... If the breaker is off... the refrigerator is still plugged in.. ergo FULLY GROUNDED... The likelihood of static discharge is quite remote... Just remember to ground your hand(s) to the refrigerator (always) before touching any electronics there-in.
Same reason all electronics are shipped in (silverized or PINK static) bags...
So get that MAKE & MODEL... check the sites below...
Any questions comment me back... I shall return
(my baby is having her 50th) needs sympathy too.
appliancepartspros... recommend... (also try, 3 estimates!)
SEARSPARTSDIRECT.COM
Partssselect.COM
repairclinic.COM
Easyapplianceparts.COM
Search Over 2 1 Million Appliance Parts
Water Filters Lawn Garden Appliance Parts
http://partssselect.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Find Your Appliance Parts
Mar 26, 2016 | Refrigerators
I have a Dewalt 625e type 2 router which just quit working. I replaced the switch and the PC board but it still doesn't run.
Check both brushes. Some DeWalt brushes have a spring loaded plastic pin built into them so when it wears down the pin pops out and prevents damage to the armature. Other brushes have a copper wire that, when the brush wears to a certan point, it will no longer touch the armature again preventing damage to the armature.
Dec 07, 2012 | Tools & Hardware - Others
I purchased brushes for my 12 volt dewalt drill yesterday at the Dewalt warranty store in Denver. Today I took the housing off the drill and it does not have the same type of brushes in it as the...
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
Mar 24, 2011 | Dewalt DC727KA 3/8" 12v Cordless...
My dw718 chopsaw is making a funny noise, the blade seems to be stuck and smoke coming from the motor. whats wrong and can it be fixed?
Sounds like the brushes have gone bad. You should be able to get new ones from eraplacementparts.com
Feb 01, 2010 | Dewalt Chop Saw D28700
My Dewalt chopsaw is loosing power and sparks heavy in brushes
I worked at a tool rental center while attending college and learned to repair tools such as yours. Damage to the armature occurs mostly during low power situations or overloading the motor. The damage is usually visable. Notice burned looking copper windings or commutator bars. You can test with growler or meter. We would turn the commutator on an armature lathe to true the surface of the bars. If the commutator is not perfectly round the brushes will bounce thus cause the sparking that you see. Also you must clean the groves between the bars with a blade to clean out all metal filings that can cause short between bars. (Broken hacksaw blade ground to fit the groves will work fine)Sanding with sandpaper may not be perfect enough to stop sparking assuming the armature is not shorted. Moisture will not effect the brushes, and sanding them square is ok but you can put the curve back by cutting fine sandpaper into strip and wraping it around commutator and insert brush into holder against sandpaper. Not necessary thou because all new brushes are square. New brushes however will increase the tension of the brush against the commutator preventing bounce due to new spring and longer carbon. Good luck enjoy
Dec 15, 2008 | Dewalt Chop Saw D28700
Dewalt 18v. cordless drill
Hope to help.
hope your wife is ok!!
you need to get all the hair out firstly but DO NOT touch the exposed switch as it is a static switch and can fail by the tatic in you!
the problem may be that the brushes were damaged try replacing them see how that goes.
hope this helps. Sean
Jan 06, 2008 | Dewalt 18 Volt Compact Drill Kit
Whirlpool AMW5125 washing machine approx 4 years old Spin action not working
your brushes are gone its a easy job and first thing is wright down the model number of the machine its normally on the door when you open it go to ebay on you should get some for £5 ounce you have took off the motor it that easy to put back on
Nov 11, 2007 | Whirlpool AWM5125/1 Front Load Washer
Dewalt Chop Saw D28700 Logo
210 people viewed this question
Top Dewalt Welding Tools Experts
Bill Boyd
Are you a Dewalt Welding Tool Expert? Answer questions, earn points and help others
