Question about Linksys Wireless-G Broadband Router
Linksys wireless b router
I am having problems connecting to my laptop it keeps aquiring address and when it is done with that i have either a ip conflict or limited or no connectivity can some one help me to fix this problem with my laptop
  • 1 more comment
  • poohbear200 May 08, 2008
    any other suggestions that did not work
  • Anonymous May 10, 2008
    help to setup for linksys routers
  • poohbear200 May 10, 2008
    my pc is what is hooked up to my laptop and trying to connect my laptop (wireless to it ).
  • 298 Answers
You can turn off the router for 1 min and turn in back on. Try to reconnect to the wireless network. In case that it will not work just give a feedback so we can try other solutions.
Posted on May 08, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 08, 2008
    How many computers are connected to the router?
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 19, 2008
    Hi, just want to if you still have a problem. I was not able to post for the past few days.
Risricky@ai cannot install my linksys router onto my laptop
I presume you mean that you cannot connect to your linksys router from your laptop and have not used it before.
You should make the initial connection using a network cable rather than wireless. Once you have done this you will be able to connect to the linksys router administration webpage by opening internet explorer (other web browsers are available) and typing in http://ipaddress where ip address is the default ip address as specified in the router getting started or installation guide. The default for Linksys routers is http://192.168.1.1 Once you can access the Administration page you should be able to configure the wireless settings using the inbuilt wizards.
Hope you get sorted
Caltor
Sep 07, 2011 | Computers & Internet
Laptop cant find router to set or change password
You will need to connect directly to the router with a Ethernet cable to configure the wireless portion of the router. Once you have done that, then you should be able to do the configuration in the future using the wireless. If you do not have the manual, you can download it from the Linksys website.
Thanks, Jim
Feb 21, 2011 | Linksys Wireless-G Broadband Router
Trying to connect a new laptop to my linksys wireless setup and I enter the WPA key and it says it is aquiring network address, but never does. What am I missing.
Stop and start over with Router Setup by using a paper clip to press router reset button. Now, with router connected via CAT-5 cable to a computer's NIC. On this computer, using IE or other web access, go to http://192.168.1.1 to access router web setup. Set the Wireless properties, such as SSID (Network Name) and Security properties, like WEP/WPA passwords. This password will be needed by all computers accessing this router's signal. At this point, your router should be putting out a signal identified by the SSID name, all other settings for the router should be set already to the point where it will work, like the IP addresses declared in the router setup. Best left alone, at least till it is up and running. It gets the network address from your Internet Provider, and they are the only ones that can give you an IP address.
Dec 15, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys router connects and says it has an excellent signal but will not aquire an address please help
Try a hardwire computer and get into the setup page of the router by typing 192.168.1.1 on your browser . Make sure you have changed the SSID or the network name of your router to your choice. Check if you have security set. If you have one make sure they match your computer.
Nov 11, 2009 | Linksys Wireless-G Broadband Router
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Linksy router
a DNS server stands for domain name service. The DNS server translatesnames from IP addresses. The internet sees IP addresses such as 209.235.250.53 but the DNS server provided by your ISP translates it for you into fixya.com. You should be able to aquire the DNS server information from your internet provider (ISP) hope this helps.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
WIRELESS CONNECTION PROBLEM
Have you configured your wireless adapter with same WPA key that you had set on the wireless router?
Do you detect other Wireless routers in your area and are they using the same wireless channel as your router?
If so change the wireless channel on your wireless to an unused wireless channel to avoid interference with other wireless routers.
Apr 19, 2009 | Averatec 3200 Notebook
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
sounds like you need to reenter the password/key
go to network connections and disconnect from it. then try to reconnect after the refreshes.
is it asking for a password/key?
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Having problems with linksys connection
Please check if the router needed IP address?
- if yes? ( goto Network Settings and add the IP address.
- if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Sep 21, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
