Question about Hayward Navigator Pool Cleaner
How to remove pods in order to install axv621d replacement
  • 640 Answers
Your pads should come off with just the removal of a screw. Here is a copy of the users manual for these pool cleaners. It will give you detailed pictures and instructions for replacing the pads.
http://www.backyardcitypools.com/images/hayward/Navigator-manual.pdf
Posted on Oct 08, 2010
There is no factory recall on my pod xt pro
That's correct, there is no onboard recall. In order to reset, follow the instructions in this link-
http://line6.com/support/page/kb/_/pod/pod-20-podxt-family-pocket-pod-floorpods/pod-xt-series-factory-reset-reflash-and-firm-r491
Apr 06, 2014 | Line 6 New Line 6 Pod Xt Podxt Live...
Tip
How to Replace the planetary gear in an Odometer of car?
The procedure is follows:--
1) First of all disconnect the negative cable from the battery of car.
2) With flat head screwdriver, pry the gasket around the edge of the face of speedometer gauge away from the dash and remove the gasket.
3) You will have to pull the entire speedometer gauge out of the dash;
NOTE:-- do not to disconnect the connecting electrical wires when you pull speedometer.
4) Then remove the speedometer needle by turning the needle clockwise.
5) Then remove the two screws in the face of the gauge with screwdrivers.
6) Remove the motor casing for the odometer out from the dial after the screws are removed.you will need to pull the motor casing a bit to remove it out.
7) In the motor casing you will see the gear pod at the top of the motor casing. Slightly with bit force remove the gear pod. The gear pod is attached to the "lid" of the casing .
8) You will see the odometer planetary gear in the gear pod which you removed.Remove the planetary gear from the gear pod with the help of mini flat head screwdriver.
9) Insert new gear into position and reassemble the gauge by reversing the procedure.
this will help.Thanks.
on Mar 15, 2010 | Audi A4 Cars & Trucks
Where can I buy some Senseo coffee pods?
Senseo coffee pods are available in a variety of locations both locally and online. If you prefer something local, try Wal-Mart. Otherwise, I have compiled a short list of some online options for you to order from.
http://www.senseo.com/
http://www.ebay.com/sch/i.html?_nkw=senseo+coffee+pods
http://www.coffeepodshop.co.uk/Senseo-coffee-pods-c-253.html
Feb 07, 2013 | Wine & Spirits
How do i replace i pod screen ?
Hi brandon swanstrom
Go to the following webpage for help with the ipod and parts
Please rate me
Bud
http://www.ifixit.com/
Oct 18, 2012 | Audio Players & Recorders
Manfrotto 028 Tripod foot installation
If you're afraid to "damage", maybe consider buying complete 'pod next time?
Jul 11, 2012 | Photography
In my 2002 Mitsubishi Pajero Sport 2.5TD the compass backlight is not working when the lights are on. The volt meter on the left and oil pressure on the right are both OK. Is this simply a blown bulb ? and...
The bulbs work when the ignition is switched on. There are two very small bulbs at the back of the compass and can be sourced from a main dealer for around £5 a pair. Part Number MMR283314. Don't forget to order two, they come in single packs. They burn out quicker than the normal bulbs as they are on, even when other dash lights are not. The main dealer will probably have to order the bulbs from Mitsubishi UK.
To fit: Prise off the top of the instrument cluster with a flat screwdriver. Remove two screws to release the pod from the top of the dash. Once free, unclip the wiring loom plug and socket.
Dismantle the instrument pod by removing four small screws. This will then allow you to remove a further six similar screws which hold the front 'glass' and instruments together.
Undo the wire connector on the compass. You may have to also take out the bulb holder from one of the guages to give you enough slack.
Once the wire is undone, you can slip the compass from the pod and you will see two deep holes in the back. Use a flat screw driver to reach down into the holes and engage the slots on the back of each compass bulb holder.
Turn the bulb holder a few degrees to release and withdraw.
Reassemble by reversing these instructions.
Nov 15, 2010 | 2002 Mitsubishi Montero Sport
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Volume varies by itself on the Yamaha htr5840 Receiver
The pod that controls the volume knob is either very dirty or needs replaced! (If you remove knob you will see the shaft of the volume pod go into the pod itself) You may try cleaning with a can of high pressure air by spraying short bursts of air in and around the pod area! If that doesent work you will have to replace the volume pod!...Please rate my response! Thank You!
Jan 11, 2009 | Yamaha HTR-5840 Receiver
Lost Used Coffee Pod Basket
My husband threw ours away. So I inquired next time I ordered pods, and you can buy one online when you order. Just put it in the comments box on your order form (although it may be better to call and order it, as the first time I tried this they missed it). Anyway. It was like $3.50. Then my husband threw that one away too, so I gave up. ;)
Sep 29, 2008 | Nespresso C100B Essenza Single-Serve...
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Hayward Navigator Pool Cleaner Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
