Heating & Cooling Logo
Posted on Aug 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a simplcity air conditioner model 10504D and it shows a flashine "E1". Is this serious and how do I fix it?
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Aug 30, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150092
Points
26471
Hi
Thanks for using FixYa. Error E1 is Automatic filter clean reminder. To resolve this issue you’ll have to unplug the air conditioner and then clean the filter. If after cleaning still the issue is not resolved then the filter should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
I have an air conditioner portable Model: CPN10XC9, and have a problem, when I plug it into the wall outlet will not turn on and the screen lights E1. I clean the filter as the manual says and yet the E1...
I dont know what the E1 stands for but make sure that if its on an extension cord that its rated for appliance use and you might try another outlet. Sometimes the load from an a/c is great enough that the receptacle overheats and causes the problem.
1helpful
What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
h Air Conditioners
How do you fix the error code E1 on the unit?
air conditioner wont come on E1 shows up on panel
Top Heating & Cooling Experts
Paul Carew
john h
