I have a Technics SL-QD33 turntable that will play all songs on an album but only for about 7 seconds, then ejects. I've initially replaced the stylus due to previous damage which I thought would resolve the problem. Thank You for your help in trying to come to a solution to my problem. Thad Marud
  • Televison & ... Master
  • 17,130 Answers
If you meant that the arm rests for only 7 seconds before it comes back, then it is possible that there is some error on the speed or the mechanism that make it detecct and error or wrong seting to reset.
If with the strobe control then therer can be variation of the detection or the drop of servo speed of the turntable.
Also check if the set was not used for some time any linkage that is not fallingin line. Check the drive, the movement of the arms, clean , lubricate slightly and test.
DO this and comment.
Posted on Aug 31, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
A few weeks ago I sent in a question and paid the $6.00 but haven't received a response. I have a Technics SL-QD33 turntable that will play an album but only for about 5 seconds regardless of where you...
Not to be a smart a$$ but I have one too,, and I got a new needle and it was not cut right,, so I got another one and it plays great now,, I did check the weight adjustment at the rear of the arm and it was a little shy of what was needed, a half turn put it back in place and I was off and running, sorry you didn't get the paid for advice,, But this is a freebie ,, good luck
Sep 10, 2010 | Technics Audio Players & Recorders
Technics SL1200MK2 - audio issue with ''s'' sounds only
Try some anti-static record cleaner. You can also get an anti-static matt to put the records on.
Jul 27, 2010 | Technics SL-1200MK2 Turntable
Technics Turntable Auto-return problem - please help !
Great!! You're Happy, I'm Happy.
Now there's some kind of rating procedure on this screen. If you could rate my asistance, I'd appreciate it, Dan.
thanks...
Charlie
May 30, 2009 | Technics SL-BD22 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
