Question about Craftsman Garden
I have a model 917.28742 26hp and 48" cut it is a 2007. Reverse is really slow and when i put my snowblower on i cannot go in reverse on any incline. I have tried purging the tran. but that did not help at all. I know i am not the only one with this problem, so i read. Thankyou
4 Suggested Answers
SOURCE: NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
Posted on Aug 09, 2009
  • 12104 Answers
SOURCE: 19.5 hp 42 " automatic craftsman . The trans seems
recheck ur drive belt either wrong belt or spring/idler/tentioner pulley needs attention adjustment replacement also check free wheel actuator that not partially activated
Posted on Jun 10, 2010
  • 3911 Answers
SOURCE: ./model 917 273321 26hp hydro
well you need a new transmission for it. start looking on google or ebay. nobody here sells lawn tractor transmissions.
Posted on Aug 29, 2011
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When i start the car and put in reverse, car cuts off. if it doesn't cut off in reverse it does in drive. then the car shudders, especially when slowing down.
how about scanning car and giving it a tuneup-clean throttle body and IAC then maybe change plug wires and dist cap--purchase a haynes book for maintenance-adios
Feb 28, 2011 | Hyundai Elantra Cars & Trucks
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet Model LT1042 (2007) The reverse mode does not function.I turn the switch to reverse mode & push the button for reverse mode and the light does not indicate on and I cannot reverse mow since...
Nearly all lawn tractors on the market are designed to kick the cutting deck out of drive when reverse is engauged.
This is controlled by a simple electronic microswitch which can be disconnected but I would advise to leave it as it is ;)
Oct 11, 2009 | Cub Cadet Garden
Garden Logo
71 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
