How do I put transfer information from my computer on to a cd. My new computer doesn't have a floppy disk so I have to use a cd.
    Guru:
  • 1,342 Answers
You will need a CD burning program such as Nero Burning Suite or Creative CD Writer or here is a link to a FREE one.
Posted on May 08, 2008
I want to transfer data from a floppy disc to a cd
Your computer must have a floppy disk drive in order to read data. You have to buy one or borrow computer (from your friend maybe).
Oct 18, 2011 | Samsung CLP-600N Laser Printer
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
No go
If you can get into BIOS check your boot order.  Set you HDD to first, then CD, then floppy, remove network if listed.
Oct 23, 2007 | Computers & Internet
I have some floppy disks with pictures on them from as far back as 1998. When I put them into my computers A:/ drive i get a message that says -- A;/ not accessable No ID address mark was found on floppy...
If your not computer savvy like the address might be holding you up or go into bios to see if it is being reconized(floppy drive) you can take them to a computer tech shop and they will transfer them for you
Feb 17, 2011 | Dell Dimension 4400 PC Desktop
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
Copy files from old computer and transfer to new computer
Although Vista comes with an Easy File Transfer Wizard it is not compatible with Windows 98.
May 08, 2008 | Computers & Internet
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Won't power up
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
And i forgot :
Nov 20, 2007 | IBM ThinkPad T20 Notebook
Hi pc wont start
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
And i forgot :
Nov 03, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
