Question about Kenmore Dryers
Blowing thermofuse on heating element - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Replace the thermostat also...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
My phillips single oven has power, hard wired power supply showing lit. But when turning the oven on, no response. What should I do?
If you have a multimeter I would FIRST turn off the power and disconnect the heating element and do a continuity check on it. Phillips elements are not all that durable, so that is probably the problem, but it could be the thermostat or switch also. Some Phillips also have thermofuses that seem to blow for no aparent reason.
Jun 22, 2011 | Philips Ovens
The thermofuse that comes before the heating element is blown. Even when I jump it the element doesn't heat up. Once I replace the thermofuse will this solve the problem? Thanks Ray
I'm afraid the answer to your question is no it probably won't fix your heater. I think your element is bad or it should have worked when you jumpered it. Sorry I don't have better news. Thank you
Dec 27, 2010 | Bionaire BFH5000UM Electric Heater
Will not heat
it is either the heating element or thermofuse either way you will need to pull the front panel off. The screws are inside the dryers door frame, the pry up on the top it will pop up, disconnect dryer door switch lift top lid to a 90 degrees. the element is backside right looks like a spring, visually inspect, the thermofuse looks like a resistor that has two clips you can pull the clips off and tape them together and if you get heat then you will need a new one. Hope this helped tim
Sep 25, 2010 | GE Profile Harmony DPGT750EC Electric...
It wont start it acts like it is getting no power
Check the thermofuse.  It is located on the exhaust and usually has 2 blue wires going to it.  It should have close to 0 resistance.  If it doesn't replace it, also replace the operating thermostat right next to it, because this should shut off the heat before the thermofuse blows.
Dec 19, 2009 | Kitchen Appliances - Others
Blowing air no heat open up dryer at the bottom on the heating element there is a burnt looks like a small relay that be the problem for no heat
This problem is usually a blown thermofuse. Whirlpool Dryers usually have two thermostats or thermofuses on the heating element case. Unplug Dryer, remove one wire from the thermostat, and with an electrical tester you need to test for continuity or resistance between the two terminals on each thermostat. If you have no continuity on either thermostat, order new ones, they usually will only sell as a set. If their is any burned wiring you have to cut out the burned section and put on new wiring terminals. 99% of the time this is caused by a venting restriction, so make sure your vent is clean and not smashed or restricted, otherwise this problem will reoccurr. If your thermostats have continuity, test for continuity across your heating element terminals. If this doesn't take care of it let me know and I will walk you through other tests
Dec 10, 2009 | Whirlpool Dryers
I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Dryer starts but wont heat
There are 2 main cause for problem;
1) thermofuse may be fault or
2) you have bad heating element.
Check if you have continuity between 2 connectors on thermofuse; a black disc usually found at the back of the dryer. If it is okey, check the heater.
It's got to be one of these.
Oct 11, 2009 | Kenmore Dryers
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
Clothes dryer wont heat
You have to first check the power getting (or not getting) to the dryer. Its uses two legs of 110V, but they are 180 out of phase with one another. If one is not getting power to the dryer, it will still run on the other leg, but no heat. check the thermofuse The thermofuse is located on the heater element housing, but that may be the problem.
Sep 16, 2008 | Dryers
Dryer thermofuse blown again
Probably restricted air flow caused by lint build up. Clean out dryer and all vent pipes, check damper outside and see if it opens. After you clean out everything run dryer on aif fluff/no heat cycle and see if there is good air flow outside. If it is electric it could be that the heating element is burned out and shorting out against the frame. This can cause overheating.
May 12, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
