Question about Acer Aspire 3100-1405 Notebook
Restore i have major fps problem that has only come on in the past month. i have tried everything but nothing works,any idears on what to try. if not then can someone please tell me how to do a system restore back to factory setings. please!!! this is really bugging me now.
  • 667 Answers
We can do your system restore but tell me about the fps problem first . No sense having you do a retore if you don't have to. If we can't get you fixed right up I'll be happy to help you with the restore. It's amazing how much angst these little things can cause ti humans! Hang in there, we'll beat it. Let me know about the fps. Thanks.
Jeff
Posted on May 09, 2008
9400 gt 512mb
Update the graphics driver to the latest version, If that doesn't help you could try completely unistalling the driver and reinstalling the latest stable version that worked well on your system.
Aug 04, 2013 | Computers & Internet
Acer Z5610 overheating when trying to play games, haven't had problem before, just started happening? have tried turning frame rate (FPS) down but nothing?
Man... About the only thing I can tell you is to do is blow a fan on it or lower the temperature in the room itsself. This is one of the MAJOR drawbacks with owning a AIO (All in One) PC. They have cooling issues and when you have a major problem with them you're almost always forced to return the PC to the manufacturer to be fixed or replaced.
May 22, 2012 | Acer Computers & Internet
Downloaded the new itunes my nano has frozen with only the apple on screen i have tried restore a few times using itunes but nothing is it dead any idears thanks ann
Try this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen, and it should boot normally. Then it should work like normal. Hope this helps you!
Feb 19, 2010 | Apple iPod nano
Server busy, close the window and try again later
Yahoo software is not noted for its generosity regarding webcams
You need to track what is happening during transmission. From the webcam frame menu click 'webcam' click 'statistics' from here you can see your frames per second. Do a few tests while broadcasting adjusting the slider (click 'file' click 'preferences') to improve quality ( at the expense of speed). If the fps drops to 0.0 your picture will be frozen.
You can also adjust your camera settings from here
Depending on your resources - internet speed - memory etc, will dictate the fps. The object of the exercise is to achieve maximum quality with a reasonable fps. Personally, I found the fps very erratic and about 0.0 to 3.0 with later mods the highest I could achieve was a modest 0.0 to 6.0 you may do better.
carry out the Yahoo mod to the registry
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamfix.html
Download the microsoft software
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstatestcamie.html
The webcam should now be controlled by VFM ( seen at the bottom of the statistics window)
Finally do your tests again, I transmit my image as 'small' ( 'webcam' > 'image size' ) and the contacts use 'Zoom' > '200%' to restore. this is to preserve what little resources I have.
Aug 09, 2009 | Labtec 961307-0914 Webcam
Apple ipod 1gb locked and dont know the combination and cant sync
Connect it to the computer you normally sync with.
Open iTunes then disconnect the iPod.
If that doesn't work you can "hard reset" by restoring it to factory defaults. Doing this also erases everything you have on it so you will lose your movies, music, files, etc.
Connect it to the computer and open iTunes.
Click "Restore" and select "Restore" or "Restore and Update" to make sure you're on the latest firmware.
Good luck.
Feb 04, 2009 | Apple iPod nano
I can no longer print to my Lexmark 6500.
hi.
if u dont have the cd,try the downloaded version from www.lexmark.com ..try connecting usb cable and check if printer works,,,if it does then its an issue with wireless connectivity..
good luck
Jan 25, 2009 | Lexmark Office Equipment & Supplies
Ipod shut off and wont do nothing
I took mine in today, its been doing the same thing for about the past month. Intermittently working. It will cut off and not respond for periods of time, then work normally, then cut off again. I took it to best buy, the geek squad "restored" it. And it did no good. It has done it twice since I was there this afternoon. Once for about 2 hours, and another time only about 15 minutes. --I'm not happy.--
Jan 12, 2009 | Apple iPod nano
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Acer Aspire 3100-1405 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
