Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
Tractor only runs with choke on , stalls when you take choke off
  • 1,498 Answers
The choke cable needs adjusting. There is a strap holding the sleeve on the carb. loosen it and adjust the choke position, then tighten it up again.
Thats it
Mike
Posted on Aug 30, 2010
2 Suggested Answers
mickey813
  • 472 Answers
SOURCE: small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Posted on Oct 02, 2009
New carburetor - starts with full choke
Try you tube to see if they show you how to adjust it
Aug 21, 2015 | Garden
Lx176wont runs on choke only
Gas cap vent could be plugged. clear it up or replace the gas cap.
Oct 19, 2014 | John Deere Garden
Mower will run then starts running bad turn the choke off and it stalls stalls after i choke it also blows gas out of the top of the carburator how do i adjust the vaalvesType your problem for a solut
Using the choke as you did,mentioned in your problem,you have flooded the carburetor. DO NOT USE THE CHOKE,ONCE THE TRACTOR IS RUNNING. Choke is used to start the motor only. When you run with the choke on,the motor gets to much gas and the plug(s) get fowled up and gas comes out of the carburetor. Remember the motor is hot,when gas comes out of the carburetor,the amount of over flow (flooding),could cause a FIRE. Lay off the choke,clean the spark plug(s),they will most likely be fowled up. The filter will be soaked with gas,remove the filter,soak up the gas,using a handy wipe,let filter dry out. Once dry replace filter. You should be good to go. Remember,do not over choke,use when starting a cold motor,usually when motor is hot from running,you may not have to use the choke at all. Hope this helps. Sincerely,Brad Locke
Apr 22, 2013 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Stalling after one hour run time
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Small engines
Sep 25, 2009 | Garden
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
347 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
