Question about KitchenAid KBRP20ERSS Stainless Steel Bottom Freezer Refrigerator
New High Voltage won't program
Has new control board,new high voltage board and a new touch pad. Followed the instructon sheet for the high voltage board and it will not program.
I had the same problem. Disconnected the leads to the low voltage board and then simply plugged the four of them back in, making sure they were firmly seated. Powered up the fridge and it started responding to the keypad and programming. Has been working normally except that after one batch of ice, ice-maker suddenly stopped working. Now I have to figure that one out.
Posted on Aug 11, 2012
    Genius:
  • 1,073 Answers
If connected right have the parts person that you purchased it from warranty the part back to whirlpool as deffective and have them order an new one
it will not cost you and reinstall the new one that you get
Posted on May 08, 2008
No lights come on touch pad its ot working
This is a difficult task you would need the tech sheet and check the voltages on the board , compare them to the tech sheet
Mar 24, 2014 | GE Profile PSW26P Stainless Steel Side by...
Mt 1510w microwave buttons not working
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Jan 24, 2013 | Microwave Ovens
The pots and pans and the normal light blinks but nothing happens
most likely you have a bad touch pad,you can first try this,shut the power down to the dish washer,open it up and unplug the ribbon from the touch pad that goes to the control board,unplug it off of the board for 5 minutes and then reconnect it the same way it came off and then run it and see if it repaired it,if not you'll need a new touch pad.hope this helps,one more thing,on the back of the kickplate or bottom panel has a tech sheet on the back of the panel,you can check it with the diagnostics to see what part is bad but most likely it will be the touch pad.good luck with your dish washer.
Oct 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Problem with my maytag neptune mde7550 dryer will not go through any cycles by useing touch screen and will not switch off by touch screen
Oct 17, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Whirlpool gas dryer model no. GGW9868KQ3. My problem is when you press any touchpads on the control panel nothing lights on. There is power going in to the control board. Do you think it's a...
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix.
Thank you for using Fixya
Aug 24, 2011 | Whirlpool GGW9868K Gas Dryer
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Apr 01, 2011 | Maytag EPIC MFW9600S
Replaced circuit board.programed board per inst sheet.touch bake pad and then start pad code f1e3comes on
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2010 | KitchenAid KESC308LSS Electric Kitchen...
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Dec 14, 2007 | GE Monogram ZET3058SHSS Stainless Steel...
KitchenAid KBRP20ERSS Stainless Steel Bottom Freezer Refrigerator Logo
243 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
