Question about Whirlpool Duet GHW9150P Front Load Washer
CONTROL LOCK LIGHT IS LIT AND NOTHING WORKS - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this and unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 25, 2015 | Dishwashers
Disherwasher will not start
Are you sure it is the Dry light that is lit, or is it the little Lock symbol located ABOVE the Dry button that is lit? If it's the latter, you can turn off that light (turn off the control lock) by pressing and holding the Dry light for 4 or 5 seconds until that light goes off.
Aug 04, 2014 | Frigidaire Dishwashers
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Jun 03, 2009 | Whirlpool GHW9300 Duet Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Duet washer
PRESS AND HOLD CONTROLS LOCK/UNLOCK (END OF CYCLE SIGNAL)FOR 3 SECONDS.
Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
