Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
How do I check and fill oil? - Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
    Scholar:
  • 97 Answers
At the lower bottom of the engine on ether side theirs a plug in a angle should have 2 knobs on it remove carefully their usually plastic fill with oil till about 1/2 inch from the top of the lower side of the threads hope this helps
Posted on Aug 30, 2010
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
1996 Honda Accord EX Manual trans. Where is oil level plug. what kind of oil?
All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug.
The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
  1. The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
  2. Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
  3. If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
Sep 05, 2011 | 1996 Honda Accord
I have a portable generator, 5600. My C1 engine light came on to check oil, however there is no dipstick. How do I check oil level etc?
No dipstick then you fill it all the way to the bottom of the oil fill hole. If you have a riser type oil filler the dipstick should be attached to the cap. Worst case senerio remove the low oil level sensor and fill with oil at that point until you can no longer add oil without making a mess, I am sure there is a gray oil cap somewhere. That is where your supposed to add oil until you can no longer add oil without it overflowing.
Thanks for choosing FixYa,
Kelly
Aug 27, 2011 | Briggs & Stratton Briggs Stratton 6200...
How much oil does a 2000 mercury cougar with a 2.0 Liter need?
3.5 - 4 quarts.but check oil dipstick and slowly add to full line remember to wipe clean reinsert to check...oil filter will need to fill as well so once oil is almost filled run engine for about a minute then shut off and fill to full line.
Mar 18, 2011 | 2000 Mercury Cougar
How much oil what wt.
Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
Feb 03, 2011 | Porter Cable PorterCable DBSI325 3250 Watt...
How do you cheak the oil on a 1997 1100 virago
Motorcycles generally use one of three methods to check oil level.
1. A "sight glass" or small window which will allow you to see the oil level. (it should be at the mid point of the sight glass. Check it with the bike upright and not leaning on the kickstand.
2. The fill plug may have a short dipstick attached to it just like a car would. Again check it with the bike upright.
3. If no other method is used, then open the fill plug and fill until the oil level just reaches the lowest part of the fill hole without spilling out. Once again do this with the bike in the upright position.
Check to make sure the rubber O-ring is in good condition and is properly seated on the fill plug while you are at it!
Oct 09, 2010 | 2001 Yamaha V Star 1100 Classic
1991 mr2 oil warning light
try to disconnect battery behind drivers seat to reset computer then check oil pressure sensor
Mar 31, 2009 | 1991 Toyota MR2
Oil change
underneath the engine at the lowest point there is a bolt about 17mm undo drain oil then put 17mm plug in fill the new filter with new oil before screwing back on and place oil around rubber ring on new filter so it seals properly fill with oil to low point on dipstick start car check oil filter for leaks turn car off let oil settle and check level again too much oil in a motor will cause problems so dont over fill hope this helps glenn...........
Dec 15, 2008 | 2006 Suzuki Grand Vitara
Drain and change oil
I can't tell you all the particulars from the limited amount of pictures of your bike. -Remove the oil drain bolt on the bottom of the crankcase (the universal bolt size for bikes use a 17mm wrench). -Drain the oil (remember to recycle). -Re-install the drain bolt with a new sealing washer if necessary. -The oil fill cap should be some where on the top of the crankcase. About 1 or 25mm in diameter with a raised tab for turning. -Fill with recommended oil. -There are 2 ways to check oil level on dirt bikes: 1) Oil level check bolt. On the right side cover. 2) Oil level site glass. A 1 round piece of glass on the side of the crankcase. Usually by the kick start & R brake lever. -Always check the oil level with the bike upright (as if you were sitting on it). -Check bolt - fill with oil slowly until oil comes out of the check bolt and re-install it. -Sight glass - fill with oil to cover 3/4 of the sight glass. -Remember to hold the bike upright when adding oil.,
Nov 10, 2008 | 2008 Derbi Senda Baja 125 R
How do i check the transmission fluid
transmission fluid you can check easy way the gear box is one oil to be so you can see in the middle of the gear box filling plug remove that with spanner if you see oil coming from hole that is fine you don't put more just putted back and tight. if you don't see any oil just use your finger front part through if the front part of your finger touch the oil that is also fine means ok. but is the oil is very low from that place you must fill.
To get the level if you fill the oil you stop filling when you see oil is draining so you wait until oil stop clean the aria then you fixed back the filling plug or bolt tight.
that is my advice sorry any mistake of my tipping.
Oct 26, 2008 | 2003 Oldsmobile Alero
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
52 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
