Question about Dell Dimension 3000 PC Desktop
I am trying to install two 1gb ddr pc2-4200u ram into my Dell Dimension E310 desktop. I currently have two slots, I removed the original 256mb stick to make room for my two 1gb sticks. When I boot the computer after correctly installing the two new sticks, the montier is all scrambled in various colors and I can barely make out a message that says something along the lines of "Decompilation not prohibited". When I remove the two new 1gb sticks and replace it with the original it works fine. HELP! I've also tried just using one of the new 1gb sticks and it still has the same problem.
  • Dell Master
  • 1,183 Answers
I belive the problem is caused due to non compatible memory being installed . According the Dell documentation the memory specification is as under
333- and 400-MHz DDR SDRAM
1Gb Non-ECC on each slot.
Just check the speed of the memory you are trying to connect.
Dell Documentation
Thanks for using Fixya
Proton
Posted on Aug 30, 2010
Can a dell dimension 2400 have 2 GB of memory, right now I have 1 GB
Please open up your pc and make sure the RAM card is inserted correctly, if it is inserted correctly, it is probably that the Ram has gone faulty and you will need to replace it, but they are so cheap.
Hope this helps
Mar 23, 2011 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 4600 and would like to install 2 one GB memory sticks. I would like instructions on how to install them
Go to this site for information about the 4600.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm#1111336
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
Dell Dimension 3000 PC Desktop Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
