Question about Maytag Washing Machines
My maytag washing machine started smoking while washing a load
appldoctom
  • 311 Answers
SOURCE: How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Posted on Jan 08, 2009
SOURCE: Maytag front loading washing machine
3E has something to do with the motor control. Apparently the design of this machine allows a water leak either from the water intake box or down a rubber hose which runs along with the motor wire harness. The water tracks to the harness and motor and shorts the whole mess out. a.k.a. fried motor.
pull the back plate off (3 screws) and look at the motor where the wire harness plugs into it. Notice a bunch of green stuff- that is corrosion from the electrical short circuit causing your problem. See the rust build up on the side rail below the motor (as there will be none on the side adjacent) this is indicative of a water leak.
Our machine started doing this within the first week and we had the "service" people come out and "fix" it, but it appeared they did nothing. When I opened the machine up I discovered the problem when I ohmed out the rotor contacts in the motor wire harness and found it to be open instead of the factory specs of appx 2.5 ohms.
Maytag (now Whirlpool) does not want to send me a new motor and harness because of their bad design. The machine is a sealed unit only 23 months old. Note to all...do not buy Maytag or Whirlpool. That Maytag repair man is sitting on his bum because the company does not care about their consumers and their cheaply made products (sold at high markups).
If you want pictures write me at aboxoffrogs@optonline.net
Posted on Dec 24, 2007
huuum
  • 750 Answers
SOURCE: smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Posted on Oct 06, 2008
  • 6 Answers
SOURCE: top loading Maytag washing machine is overflowing
water level switch is bad
Posted on Mar 30, 2009
SOURCE: Maytag Ensignia Smoking
I had the same exact problem, called a repairman to take a look..he informed me the motor has burnt out! His first thought was the transmission, and said having the motor burnt out is better since it is less expensive.
Posted on Jun 03, 2009
Smoke was coming out of my washing machine
That would indicate either that either the electric motor is starting to seize up or the belt is slipping.
Oct 22, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag frontloading washer - MAH4000AWW- after last load, when I opened the door, there was a slight burning smell and a little smoke - could it be a belt? the motor?
Usually this a sign that the bearings are slowly starting to cease not dangerous but eventually will get louder as time goes by
Jun 10, 2011 | Maytag Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Washer smoking
If it's smoking you have a serious electrical problem in the unit. Unless you're experienced in electrical problems call a repair service for this one. It's not worth burning the house down to save money on this one.
Apr 26, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washing machine won't run with load. The belt started smoking. I unloaded and everything runs fine.
i would suggest replacing that belt. most belts are desinded to slip, but after awhile they will lose grip from wear on their side.
Jan 18, 2010 | Maytag Washing Machines
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mar 21, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Burning smell and smoke
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Feb 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
177 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
