Question about Sony KDS-55A2020 55" Television
My tv does not power on. Blinks green, then red. I replaced the bulb recently, it was blown, but now it still does not power on. Any other problems with this tv that could be the cause?
Did you ever find a solution to this problem? The same thing happened to my tv today.
Posted on Dec 31, 2010
I have the same problem. Can a bad lamp affect the sound?
Posted on Oct 12, 2010
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block.
It is quite involved to replace, if not technical get professional help.
Mar 21, 2014 | Sony KDS-60A2020 60" HDTV
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
XL 5200 bulb replace and tv still down
3 blinks means the lamp cover door is nit properly attached. Remove the lamp door and reinstall it
May 28, 2009 | Sony KDS55A2000 55" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KDF-E42A10 42
I replaced the bulb recently on my tv and did not push the bulb all the way in. I had the same issue you are having now, and I was able to get it to work when I realized it had not been installed properly. Make sure you push the bulb in all the way then push down on it so it sets in nice and snug. Sounds like someone replaced the bulb and installed it wrong like I did the first time. Good luck.
Feb 17, 2009 | Sony KDF-E42A10 42 in. LCD Television
Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Oct 29, 2007 | Toshiba 46HM95 46" HDTV
Panasonic 61inch tv
mine did the same thing, call panasonic its the buld blown. just had mine replaced under warranty for 18 months after that bulb is 284.00 they've had a lot of problems with the bulbs in these tv's you can search gooogle for them
Oct 05, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Sony KDS-55A2020 55" Television Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
