Question about Cisco Computers & Internet
3550 Cisco switch
I already have 2 of the same switches and want to connect a third. My 1st switch is cabled at port 24 to the 2nd switch at port 24. Where would I connect the 3 switch with the other two?
  • VOPETTE May 23, 2008
    I actually had to call in the "big dogs" to help. I am dabbling in this for my agency and learning as I go, with some formal training along the way. Hopefully, one day, I'll have a clue!!
    Problem Solver:
  • 8 Answers
It does not have to be port 24 to port 24 - You just need to make sure that whatever port you use is configured the same way as port 24 - Example: Log into switch #2 and set port 23 with the same attributes as port 24. Also log into you new switch and make sure port 23 (or 24) is configured the same as those on switch #2. You can the cleanly go from switch #1 - port 24 to switch #2 - port 23 AND switch #2 port 24 to switch #3 port 23 - If you also configure switch #3 port 24 like the others you'll be ready for any additional expansion
Posted on May 22, 2008
  • 39 Answers
Agreed and if you are using any vlans make sure you make that link between them a vlan trunk
Posted on Jan 24, 2010
How to replace power supply for cisco 3550-24 switch
Hi'' as you have purchase a new one, uncover side of your unit then try to learn and have a diagram by copying in each where the all wires go '' or take a photo of it,''' thanks
Sep 01, 2012 | Cisco Catalyst 3550 Ws-c3550-24pwr-smi 24...
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
Hi Dear, My Name is sajid. I am facing problem in catalyst 3550 switch. in which ports already kept going up/down continously
Can you post the contents of your running config to this post?
Telnet into your switch, and use the command show run - copy and paste the output
Jan 21, 2011 | Cisco Catalyst 3550-24 24-Port Ethernet...
Console interface problem on the switch
HyperTerminal sucks. Use PuTTY and make sure you have the correct baud rate of 9600 set.
Putty Link:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 30, 2010 | Cisco Catalyst 3550-24 24-Port Ethernet...
''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Jun 01, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Not enough info on this problem but you could always check the IOS version and upgrade it although the Cisco 3550 is end of life.
Apr 06, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Connecting to console
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
Dec 25, 2007 | HP ProCurve 2524 24x10/100 Mbps Networking...
Computers & Internet Logo
583 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
