Window Air Conditioner Sweats
This sweating causes moisture in the window sill and the wall, which in turn causes rotting of the wood. How do I stop the sweat?
You need to seal the portion of the air conditioner that is inside the window from the portion that is outside the window, Sweating is caused by moist outside air leaking in and contacting the cold portion of the air conditioner. Do not use duct tape, buy aluminum tape which is what professionals use to seal air leaks on ducts. Home Depot sells the tape. Buy the smallest quantity you can find that will do the job ( it can be expensive ) unless you plan to go into air conditioning duct installation.
For best results use some form of insulation over the accordian like side baffles ( cut to fit) . Styrafoam from packaging or silver backed insulboard (Home Depot). Now tape the sides of the insulation to all sides of the window frame, bottom of the window, the sill, and the air conditioner.
Unless you enjoy doing this every year - plan on this being a permanent installation. It is a tedious job because the aluminum tape is not very forgiving and has a peel off backing but it sticks forever.
Posted on May 08, 2008
I have a 1938 Morris 8 at the rear of the car what holds the body up on the chassis as the body sits on the fuel tank filler
they take a lot of lining up, it also depends on the temperature you are doing the work in as the wood sweats and gets wider or shrinks, you need to make the room so that the would can shrink
Shrinking and swelling occur as the wood changes moisture content in response to daily as well as seasonal changes in the relative humidity of the atmosphere, i.e., when the air is humid, wood absorbs moisture and swells; when the air is dry, wood loses moisture and shrinks.
Jan 01, 2018 | Morris Cars & Trucks
I have a dark spot on my hardwood floor under a window. There is a small change in surface texture, but no cupping or cracking. Any thoughts?
the indications are that there is moisture getting into the timber and causing wood rot
as it is under a window I would be investigation where water could be getting in past the outside cladding and getting to the edge of the floor at the wall in that area . possible leak in at the window sill ends /area
Sep 01, 2016 | Vacuums
Aez05lqw1
remove from window, take outside and clean
Jun 21, 2014 | Whirlpool ACQ158XP Wall/Window Air...
House windows icing up indoors
If your house doesnt have a roof ridge cap vent in the center all the way across the house then moisture will stay on the window pane and sill and cause mold and rott.
Jan 01, 2014 | Heating & Cooling
Condensation window air conditioner unit
change the condensed water pipe
Sep 10, 2013 | Heating & Cooling
Thermostat on whirlpool window unit keeps resetting to 86. will not cool room.
Check if the compressor runs when you start your air-conditioner. If it runs, make sure the evaporator sweats and the condenser at the back blows hot air. If not, you have freon leak and check for oil marks inside your a/c unit.If the compressor does not start, check your compressor overload, capacitor, and use a clamp meter to determine if you have a defective compressor.
Sep 01, 2011 | Whirlpool Electronic Window Air...
Air conditioner sweats profusely into the room
Hello my name is Heath it will be my pleasure to assist you. If the condensation is running in instead of outside then the window unit is probably leveled the wrong way try and lean the unit toward the outside to get the water to run backwards toward the outside so the water can run back.
Jul 17, 2010 | Heating & Cooling
I have water running from under the passenger side interior floor board what could it be coming from or has any one else experienced it really flows when turning corners
It sounds like condensed water from the air conditioner. Just like a glass with ice in it sweats, the cold part of an air conditioner sweats. That water needs to go somewhere. There is a drain on the bottom of the ductwork that comes out under the car, often toward the passenger side.
If the drain gets plugged, the A/C still sweats, but the water builds up inside the ductwork.
You can often clear the drain by blowing some air up the drain from the outside. (Don't use too much pressure!)
Jun 15, 2010 | 2000 Pontiac Grand Prix
Refridgerator door sweats and leaks on new wood floor
indicates that the door has a bad seal or needs adjustment to make the bottom the door seal properly
Oct 20, 2017 | GE Refrigerators
Installing room airconditioner
what i did was buy a 2x6 cut them all into about 18 inches in length screwed one piece onto the window sill and the other 3 i screwed into that piece going out the window so the a/c unit sits on the wood pieces and clears the window sill that way i dont have to worry about the a/c unit weight on the window it was all on the wood pieces sticking out
Apr 28, 2008 | Heating & Cooling
Heating & Cooling Logo
550 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
