Question about Garden
Ryobi rht2660da hedge trimmer starts but will not rev fully and cuts out on full throttle thisproduct is brand new
Same problem am taking back
Posted on Jul 17, 2012
  • wightmovessa
    wightmovessa Jul 17, 2012
  • 718 Answers
If it brand new take it back to where you bought it, it's probably still under warranty. Why try to fix something you don't need to???
Posted on Aug 30, 2010
Can you help
Sounds like the cable in the upper shaft is broken. Start it without the attachments installed and see if the cable is turning.
Sep 01, 2014 | Garden
Two stroke ratio calculator
If you are referring to the fuel mixture, it is 50:1. So for one gallon of gas, use 2.56 oz. ( US measure) of two stroke oil. Gas Oil Mixture Ratio Calculator
Jun 30, 2014 | Garden
Starts ok revs ok for a short time then cuts out
The problem your having is your not geting enough fuel into the engine. reconditioned equipment will have some ware on it causing it break down faster.
If your machine manual tells you to use 50:1 ratio use 32:1-40:1 because 50:1 has less oil in it to lubercate engine than 32:-40:1 new/recondition equipment when run older equipment from the 90's 32:1-40:1 fuel ratio will run better and last longer. You may have to adjust mixing screws on carburator for the 32:1-40:1 ratio, but you notice better performance out of your trimmer and it will may start faster.
Oct 05, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Got the new Ryobi RHT2660DA petrol hedge trimmer today. Have mixed fuel to instructions and followed every step to the letter. It starts fine, but keeps stopping when I excelerate it, any ideas?
It is running too lean on the mixture, if it was new return it for re tuning, it will be an easy fix which will only take a few minutes.
Jan 21, 2011 | Ryobi Garden
Strimmer will not start got spark & fuel ryobi rbc30sbt
its probabley your throttle cable , try pulling the throttle full on when you starting up the trimmer word of warning though only do this on a very flat surface..
Nov 23, 2010 | Ryobi Garden
My hedger turns off when I turn it side-ways to
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Jul 11, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Hello I have a Ryobi HT26 hedge trimmer that is one year old. It starts fine but dies after I try to release the choke and pull the throttle. I cleaned the air intake that was semi plugged, replaced the...
Sorry but I have the same problem, did everything you did plus bought a new carb. I think these are just a bunch a ****. I have Ryobi electric tools which are okay but I am NEVER going to buy a buy Ryobi gas product again>
Nov 22, 2009 | Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
250 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
