Question about Sharp Aquos LC-PD50U 50 in. Plasma Television
LC-37AF3X Sharp Aquos KCD TV
Red Power and sleep lights flashing together and can't get TV on Sharp Aquos LCD TV
  • 8 more comments
  • chappo May 08, 2008
    Red Power and sleep lights flashing together and can't turn on TV - SHARP Aquos LC-37AF3X
  • Luthra Arun Jun 07, 2008
    power on the tv the picture comes in for couple of seconds and then the red power lights starts blinking and no picture. switch off from main switch on same thing happens
    all off a sudden the tv stopped and red power light started blinking. if you power off from the main and switch on picture comes for a couple of seconds and goes and again red light blinking
  • Anonymous Jul 19, 2008
    Sharp Aquos LC 45GD1E power light keeps flashing red, no tv at at all, have tried switching off at mains, but no difference.
  • Anonymous Aug 18, 2008
    When you turn on the tv you hear the sound and see the tv, but after 2 seconds the screen goes black and the red power led flashes you cant turn on or off except for turning off power at wall
  • Anonymous Nov 19, 2008
    My brand new sharp aquos just stop working 2 days ago, the power and opc green ligths are constantly blinking and the screen it's just black.
    Actually I'm in another country and I don't know the steps to use the warranty of my product.
    any help will be appreciated
    Regards
    Marlon / Venezuela
  • Anonymous Jan 04, 2009
    I just bought a Aquos and after pluging everything, I turned it on.
    the green power light just blinks and no tv image, screen is black
  • pierrre Apr 16, 2009
    My sharp aquos LC32D43U (2 years old) just stop working today after 2 minutes. The power and opc green ligths are constantly blinking and the screen is just black. The remote doesn't work at all, I have to unplug the TV to switch it off.
  • Anonymous Mar 22, 2014
    no pwer
    will not turn on
  • Sharp Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Hi, i have a 46"
dear user,
supply capacitor are weak.kindly change the capacitors
Feb 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Apr 26, 2010 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-PD50U 50 in. Plasma Television Logo
1,051 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
