Question about Canon PIXMA MP180 All-In-One InkJet Printer
Paper jam in printer - Canon PIXMA MP180 All-In-One InkJet Printer
  • 13 more comments
  • joeyplay May 09, 2008
    I have a paper jam in the back and the "teeth" of the paper holder in rear has the paper. You cannot see the paper from the inside, front, only from the back. Is there a release I am not seeing? LexmarkE332 Laser Printer
  • Anonymous May 29, 2008
    Paper is jammed in the lower portion of the printer
  • mp 370 Jun 22, 2008
    Paper of my MP370 gets jammed; when starting print only the right bottomside of the paper is pulled by the rubber wheel, the left side is not going along so paper is tilted and gets stuck
    Anyone?
  • natalie21 Oct 06, 2008
    paper jammed in back cannot get out cannot see anyuwhere with all trays removed
  • corsamartin8 Oct 18, 2008
    I have the same problem no paper in the pinter but I still get a paperjam message. No Idea how to fix it.
  • Anonymous Nov 03, 2008
    I have the same problem, i can hear the paper jam its screeching, but cant see it anywhere, even with front, back and the top open...... can i pull it apart some how??
  • christine214 Nov 04, 2008
    Lexmark E240 paper jam. The paper is tightly wedged in the back area. I can't get it out using my fingers. Is there a wheel or any other lever to move? I don't see any other ways to open this thing up. I've taken out the toner cartridge and the machine is off and cool. Thanks!
  • kgc62000 Dec 04, 2008
    I pulled as much paper out from the back and from the inside as I could. The remaining bits are tightly jammed in there, with no way to remove them. Is there a wheel, or a way to open up the top of the printer?
  • microlabf Jan 29, 2009
    I have the same problem! there is no paper in the printer but it says paper jam. please help us to solve this problem!
  • Anonymous Feb 06, 2009
    ther eis no paper in my orinter, but it keeps saying paper jam, i have the front and back open. no paper.
  • Bill Printer Feb 22, 2009
    Paper jam in the HP Deskjet 970cxi. Rollers are not allowing paper to be removed. thanks
  • padilla83 Feb 28, 2009
    I have the same problem,I constatntly get a paper jam out of nowhere when I am attempting to start printing,any ideas if this is a technic al issue or is it a internal issue???thanks in advance
  • dlv8993 Mar 08, 2009
    I have the same problem. There is no paper in the printer, I've checked all the areas where it could be stuck, and there is no paper. I continue to get the message, and cannot use the printer to print, copy or scan.
  • Anonymous Mar 16, 2009
    SAME. i hate this printer. don't buy it.
  • Daniel Blask
    Daniel Blask May 11, 2010
    --what type and model printer?
    --is it a real physical jam or just a ghost jam that you can never find?
I HAVE A PROBLEM OF PAPER JAM CANONMP180 PRINTER. WHEN WE START PRINTING PROCESS AND COMPLETED THE PROCESS. THE PRINTER SHOWS A MESSAGE CANCEL PRINTING.
Posted on Mar 20, 2009
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Says I have a paper jam, but can not find any paper in the machine
Hi, If you have ever operated a printer, you have experienced a paper jam. At some point, some piece of paper has loaded off-kilter or wadded up inside the rollers. In most cases, removing the jammed paper and getting the printer working again is relatively easy.
Step By Step
1. Verify that you have a paper jam. Sometimes the printer will send you a message that there's a paper jam. Sometimes you get the message from the crinkling, squealing sound the printer makes as it jams.
2. For most consumer models there will be only one sheet of paper threading through the machine at a time and a straightforward path from the paper feed to the output tray. In that case, you will want to search visually. Look to see if there are pieces of paper sticking out where you can see them. For larger commercial printers, where the paper path is more convoluted, you will need to consult the paper jam status message for hints of where to look.
3. Remove any paper from the paper trays that you suspect might have caused the paper jam. If a sheath of paper might prevent you from getting at the jammed paper, then remove that too.
4. Most consumer printers have an access door in the front that you can open to get at the jammed paper. With laser printers there's usually a toner and drum unit that slides out for improved access. If you still can't see the jammed paper, check if there's an access hatch in the back of the printer.
5. Gently remove any crumpled paper you might find. Gently tug on any pieces of paper that may be stuck or crumpled between rollers. It's possible that yanking the paper too hard in the direction opposite the normal direction of travel could wreck the printer rotors or some other delicate part. Whenever possible, pull the jammed paper in the direction of normal motion through the printer and avoid using excessive force.
6. Avoid ripping the paper as you remove the jam. Pull the paper slowly with both hands. Any shredded piece of paper stuck in the rollers will cause yet another paper jam. While you're at it, check for foreign objects that may have caused the paper jam in the first place, such as a paperclip or a pen cap.
7. Laser printers sometimes get the paper jammed so deep in the fuser unit that you can't reach it with your fingers. In those cases you want to avoid poking at the paper with sharp metal objects. Scratching the rollers could permanently damage your print quality. Removing an accordioned paper jam may involve disassembly of the fuser unit by a trained professional.
Dec 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
How do i fix a paper jam on my printer?
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Oct 02, 2010 | Office Equipment & Supplies
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
531 people viewed this question
old marine
old marine
