I have a verbatium external hard drive USB 2.0 1TB. The green power light will not come on. How can I tell if it is getting power?
  • 51 Answers
Feel the hard disc... u can feel it spin/ vibrate if its powered...
Posted on Sep 18, 2010
Light flashing, HDD will not load, burning smell, not working please tell me my data has not been lost
being an external hard drive did the burning smell come from the connected computer or your external hard drive
open up the connected computer check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and possibly overheat
hope it helps
Apr 24, 2012 | Samsung G3 Station 1.5TB USB 2.0 External...
I have a Verbatium USB160 S/N JH8Y01 When I plug it into my laptop all I get is a flashing light on the drive. It did work at one time and I was able to back up to it. I read that the usb cable that came...
Does the drive have external power (D.C.) adapter? If not try to use a 2 ended usb plug to make sure the drive is being powered up. Does the computer see the drive? go to my computer\manage\diskdrives
Jul 12, 2011 | Verbatim 160GB USB FireLite: The "drive...
Unable to open my files on my external hard disk pls help
if you cant get to this external hard drive to view its files
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jun 15, 2011 | Imation Apollo UX 2.5" USB Portable (250...
SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm SimpleTech SimpleDrive Portable USB 2.0 60GB wont show up
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
hope this helps
Apr 22, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Western Digital 120 GB Hard Drive
Well usually external hard drives are just a regular hard drive in an encolsure! You can try to mount the hard drive to a regular pc using the ide/sata connector(Im not real sure which interface your drive will use). From there you can tell wether its the actual drive that is giving trouble or just the USB enclosure! Most of the times with those name brand external drives its a lil complicated to figure out how to take it apart to take out the hard drive. What you can also do is try(if you get it open) to see if you can unplug the hard drive from the enclosure then power on the enclosure and see if the lights come up green(or whatever color it uses to indicate ready)! if it does then power off the enclosure then re-connect the drive to the enclosure and power on again! Maybe that works! Removing the drive might void your warranty, proceed at your own risk! Good Luck regards, babb
Apr 30, 2007 | Western Digital (WDXU1200BBRNN) 120 GB...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
