Printer typeF4180AIO prints colour but not black, have changed black cartridge without result. This printer was purchased only in November 2007 at PC World.
    President:
  • 2,712 Answers
Hello maury jones,
  • Make sure that the cartridges are placed in the correct slots. Also ensure that they are seated properly.
  • Make sure the contacts are not dirty. You can try cleaning them with some isopropyl alcohol and a cotton bud.
  • Make sure you have the proper settings in the printer properties.
  • Dont use refilled cartridges. Ensure you only use original products.
  • If the basic troubleshooting steps dont work, try reinstalling the latest version of your printer's driver. You can find the latest drivers HERE. Make sure you choose the correct OS!
  • Should all this fail, you will probably want to get your machine serviced.
Hope that helps! Don't forget to rate this solution a fixya if it helped you in any way :)
Cheers!
Irishdruid
Posted on May 08, 2008
  • Swilin Sampson
    Swilin Sampson May 08, 2008
    PS..forgot to mention, don't forget the nozzle test. Also ensure that you clean the head of the cartridge with a cotton swab dipped in isopropyl alcohol to clean off any dried ink that may be resident there.
    Genius:
  • 3,422 Answers
You need to make the procedure of head cleaning several times after replace the cartridge, cause sometimes some air get inside the print head in the replace. Sometimes you have to repeat the cleaning procedure 10 times. Do a test after each procedure of cleaning, and watch when it was enough.
Goodluck,
Please don't forget to rate the solution
    Brigadier General:
  • 3,614 Answers
Have you tried do maintenance check..? clean first the print head & together with do a nozzle check..
Post back here again, for more assistance..
Thanks
  • micromaster
    micromaster May 08, 2008
    BTW... you don't have to worry the printer was under warranty..
My printer suddenly prints all black pages.
are you using 3rd party cartridge if so replace them all with OEM cartridge.
Sep 28, 2015 | Office Equipment & Supplies
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
I have a X3350 Lexmark printer. I do not require color printing at any time. How can I print black only using one black cartridge only. The color cartridge is never used.
let the colour cartridge be inside the printer.if its empty then also black will print.but its necessay that the colour cartridge should be in the printer as without the colour cartridsge in the printer the circuit does not gets completed.but the cartridge should be inside the printer if its empty no problem you can just print in black it will print.
Mar 02, 2009 | Lexmark X75 All-In-One InkJet Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Printing problem with Canon iP2600
Appears to be a defective color cartridge. Verify the printing is not set to fast or draft.
Dec 15, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Printing and copying colour wrong
Please change your printer's colour cartridge. after that the issue will resolve.
Nov 23, 2008 | Brother MFC 420CN All-In-One InkJet...
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Dell All-in-One Printer 964
I tried all the above and it is stll not reading the ink levels.
Dec 22, 2007 | Dell Photo 964 All-In-One InkJet Printer
Not print and not scann without colour cartridge
All cartridges must be present before the printer will operate. Essentially black is obtained by printing all colours together. Some makes/models of printer will allow black printing only for text printing. This is a printer 'PROPERTIES' function and you will have to seek this out by reading the manual fully. You could also try- Technical Support @ Canon Also www.fixyourownprinter.com
Jun 06, 2007 | Canon PIXMA MP150 All-In-One InkJet...
22 people viewed this question
k24674
jasbo
jasbo
