Question about Poulan Garden
Trimmer will run for a few seconds and then stop??
  • 718 Answers
First check to see that your fuel lines are in good condition , then if still giving you trouble rebuild carb, Go to smalleng.com they have great rebuild videos.
Posted on Aug 30, 2010
3 Suggested Answers
  • 20 Answers
SOURCE: the trimmer stop working while i was using it. the
switch is gone there is a spring inside the switch probably get a new switch
Posted on Aug 29, 2009
hunter19_46m
  • 7482 Answers
SOURCE: gas trimmer runs for a few seconds and then stops
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Gas trimmer runs for a few seconds and then stops
they were in/out.
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Have a homelite grass trimmer crank ok run ok will trim grass for about 2 minutes then stop if you crank it and run for few seconds and the give it the gas it will not take gas just stop have replaced both...
they were in/out.
Please do not forget to rate me, Thanks
May 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Adjusting the carburator on a craftsman 25cc line trimmer
Replace all of the lines before any adjustments, too small to see air leaks are a common cause the issue you have.
Feb 27, 2010 | Craftsman 25cc Gas Line Trimmer
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
