Question about Microwave Ovens
I have a Defy DUF236 freezer made in South Africa which blew its controller a few times because of power dips. Freezer mechanic then converted it to a standard mechanical thermostat which didn't work. Back to normal electronic thermostat which I now bought, but now I see the 7-pin power plug is gone. Where can get a description of the pins and how they must be connected?
Benimur
  • 6966 Answers
SOURCE: US Nintendo DS-Lite with converter problems in South Africa
It should work straight out with a step down transformer. That is of course if the mains supply in South Africa is 240 240 and the unit being American is 110.
This is of course not unless it was initially tried without a transformer or stepdown converter which would mean that the charger/adapter has been fried and therefore damaged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 28, 2008
  • 17 Answers
SOURCE: Are there any daewoo electronics repair outlets in
No, I do not think so. Try a company called MP Marketing in Durban. They used to do the repairs for Pick n' Pay and many of their earlier products were Daewoo rebadged as the Aim brand.
Posted on Aug 31, 2009
jocoolguy
  • 1912 Answers
SOURCE: LOCKED NETWORK: phone network locked,need to unlock to south-africa network.
Contact the service provider to get the Unlock code..
Posted on Jan 12, 2011
  • 12 Answers
SOURCE: My Defy DUF236 Freeezer's "alarm"
Yes change the defrost heating element it usually looks like a glass tube with a heating coil inside, you may also need a temp sensor. check out repair clinic.com for parts and instructions Good luck
Posted on Mar 12, 2011
rickead1
  • 1998 Answers
SOURCE: I Have an Electrolux frost
Hello, Your freezer normally goes into a defrost cycle every 6-12 hours depending on manufacturers specifications. If the freezer is going out of its defrost cycle timeing sequence one of the first parts that would be checked would be the defrost timer which is shown on this diagram as part number 23 click this link http://c.searspartsdirect.com/lis_png/PLDM/R0504211-00003.png usually though if you are feeling the sides of the cabinet and they are getting warm this is a sign that the compressor is not cooling in this second diagram http://c.searspartsdirect.com/lis_png/PLDM/R0504211-00002.png I do see a fan motor but the schematic does not give the motors location. Usually the compressor does have a fan or a large condenser path that the refrigerant travels through in which it is cooled by either one of these two mentioned. I would first open the freezer door and listen if you can hear a fan running if not then that would most likely be the issue. The compressor has to be able to cool if it cannot then the lines that travel through the cabinet will start to heat up. If you have any further questions message me back Thanks Rick
p.s motor is shown in this diagram as part number 13 and at the most expensive appliance parts which is sears the motor sells for 45.85 the defrost timer sells for 27.00 if you are looking for a repair service which state or area do you currently reside I personally repair in both Rhode Island and Massachuesetts but if you are not in this area I can help you to locate an appliance repair company. Thanks I await your reply Rick
Posted on Aug 23, 2011
Singer convection microwave oven
see this steps and fix it. God bless you see the picture attached.
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).052d2556-c90b-4f50-a4d7-344516db8003.gif
Jul 13, 2013 | Microwave Ovens
We lost power several times last night during hurricane Irene. The power has been on for several hours now and I noticed the freezer LED display is reading "88" and the fridge display is...
If you don't want to roll the unit out, then turn the circuit breaker off in the panel. The quick disconnect does not reset the electronics for the compressor. Try that and see what happens.
Aug 28, 2011 | Microwave Ovens
My refrigerator will not get cold the freezer gets cold it also has frost on the back panel in the freezer
You have a problem with the defrost circuit of your refrigerator. The frost is building up on the evaporator coils in the freezer preventing air circulation from the refrigerator to be cooled off by the coils. It is made up of three parts, the defrost timer/control module, defrost heater, and thermostat.
The way it works is that normally the compressor has power for 8- 24 hours, then the timer/module cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer/module switches the power back to the compressor again to restart the cooling cycle.
I don't know what make and model fridge you have since you did not supply it. But if you have an older model it is controlled by a timer, often it fails to advance to the defrost mode causing it to stay in cool mode. Often the problem is that the defrost heater burns out so it can't melt the frost on the coils.
If you take the panel off the back of the freezer you will find the evap coil. You can use a hair dryer to melt the ice. The heater will be attached to the coil. If you have a meter you can check whether it is burned out. Replacement parts can be found at your local appliance repair outlet or online at repairclinic.com.
Mar 23, 2011 | Microwave Ovens
Maytag Bottom Freezer Fridge only a few years old was replaced to sell the house. We just bought our house, moved in and the dishwasher wasn't working so we got a new one. Now our fridge is humming and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Microwave Ovens
Blew the fuse. I replaced it and it blew again after a few minutes.
Sorry to read about your problem, I hope this helps you out.
you have a control card problem, or a bad power control card issue..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | GE JE2160 Microwave Oven
Ice forming in my frost free whirlpool fridge
There are a few reasons why this is happening. One and usually the most common is the the heater for the coils in the freezer is not working.These heaters are controled by a timer that lets it run for a while and then shut off, this keeps the coils from freezing up and collecting moisture. 9 out of 10 times it is the timer mechanism that goes bad and it is a reletivly cheap and easy repair. Also make sure the gasket on the freezer is in good shape and not allowing outside moisture in where it can condense and freeze along the wall of your freezer, keeping the door open too long will also create this effect, but if the heater is working correctly it usually will take care of itself. You may also want to make sure there is good air flow from the unit itself and blowing good cold air around in the freezer.
Nov 16, 2010 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
I have a skandiluxe chest freezer and the orange light is on - is this right?
On my Skandiluxe CF309 chest freezer, the ORANGE LIGHT IS FAST FREEZE and should be depressed to quick freeze when adding newly bought items as the temperature will go up when you've opened the lid for prolonged periods. This is also used to drop the temperature when restoring after defrosting. REMEMBER TO TURN THIS OFF. Also, take note of the gauge in the inside of the freezer which tells you which setting to switch the dial to according to how full the freezer is, and therefore the most energy-efficient setting.
The red light is the warning or "alarm" and will light up when the temperature is too warm.
The green light is a "control" light and I can't remember what this is for, but I don't recall seeing it on in the 15yrs or so that I've had the freezer.
TO DEFROST:
(The drain comes out directly underneath the drain hole and there is no hose. Not a very helpful design. I found that if you tip the freezer forward and scoop out as much water as you can, then mop up the rest with a large bath towel, it should do the job.
BTW if you are planning to defrost the freezer (or any freezer for that matter), once you've switched it off, if you have access to a hand-held steamer, and place something like an empty plastic box to catch the ice (we used an unused litter tray as it's the perfect size to catch all the ice in an upright freezer), it saves a significant amount of time. If you don't have one, it's worth investing in a cheap one with the squeegee function so you can do all the nitty-gritty jobs around the house including the windows in no time and no elbow grease at all !!
Aug 12, 2010 | Microwave Ovens
My fridge is not very cold but the freezer it fine
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Aug 04, 2010 | Microwave Ovens
Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
May 07, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
