Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
Power failure the fax machine was saying "drum life warning" for weeks now. then i changed the drum about a week ago and tried the 1,3,# at the same time but did not clear. now it says power failure and i have turned off, unpluged the power cord and phone line and still says power failure. how do i solve this problem? thanks for your help.
  • Anonymous Jun 11, 2008
    machine is sending and receiving fine. But red light flashes and error message reads "power failure".
    I turned off, then back on, the power strip and for now, the red light is gone..... message still there. I have turned machine off, unplugged, etc.
    Scholar:
  • 45 Answers
Hi toomanyhats,
I suggest trying an alternative power cord. It could be that a fuse has blown in the cord you are currently trying to use with your printer.
If the cord is not the problem it may be a fault with the printer's power supply. In this case you may have to send the printer to the supplier for a certified Xerox printer technician to assess the printer and if necessary replace the power supply.
Hope you find this information helpful in solving the problem.
Thanks for using the FixYa service.
Kind regards
Posted on May 08, 2008
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
Jun 21, 2012 | Toshiba e-Studio DP170F Plain Paper Laser...
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Toner Life End
It should be in your menu to say you have changed the toner.
Mar 24, 2010 | Office Equipment & Supplies
Our fax machine says "change drum soon" even though we changed it yesterday. What is causing this? Thanks
When you installed the new drum, there is a sheet in the box that tells you how to reset the drum life counter. Did you perform this procedure when you installed the drum?
If you don't have it just open the front cover and press options then select 1 for drum replacement.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Changing Drum on Fax Machine
yes its as simple as changing toner cartridge
Jan 17, 2008 | Office Equipment & Supplies
We are not receiving faxes
My psychic powers tells me it's a brother 1270 fax that is not connected properly????
Jan 15, 2008 | Office Equipment & Supplies
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
303 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
