Question about Maytag Neptune MDE5500AY Electric Dryer
Have a maytag neptune dryer md55 cannot get a small enough tool to adjust legs to help balance. any suggestions
    Scholar:
  • 97 Answers
Use some ceader shake shingles ther tapered and the bugs hate it and it smells good this will shim the unit and break off what you don't need. hope this helps
Posted on Aug 30, 2010
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE
I would check the balance of machine by using a leveler and checking the bottom leg adjustment on all 4 legs then check the
suspension springs, counter weights, dampning straps etc.
Jun 10, 2015 | Maytag Neptune MAH6500A Front Load Washer
Why is my Maytag Neptune Elec Dryer MD55 chirping? How can I fix it?
Could be a bad spot on the drive belt. Each time it moves over the motor pulley it slips. If the chirp is happening at the same interval over and over I would check the belt.
Mar 28, 2015 | Maytag Dryers
Maytag Neptune Dryer, Light inside with door open, but no lights up on top and does not run, can you please help me out, or where to start?
Check the breaker or fuse box. Sounds like one leg of the 220 volts is tripped. Reset it or replace the fuse if so.
Oct 19, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Md55
Are you getting any heat at all in the unit?
Apr 28, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is there a reset code for maytage neptune MD55?
There is not a reset button but you have a control board that controls all the commands and functions on this model.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we can overnight the correct parts to you after we know what your dryer is not doing right.
We hope to get you drying clothes ASAP.
Thanks, Ella
Nov 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
Oct 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud knocking noise when aggitating
any washing m/c has adjustable legs
goto adjust these legs at 1st
using awater balancer tool to help to balancing the m/c
donot forget put the m/c over the hard floor
not over carpet not over metal basement
this my advice
thank you
Jun 09, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag top load washer
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
Jan 28, 2008 | Maytag Neptune Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
