Panasonic ty-st05s - Televison & Video
Panasonic TY-FB8HM died
Wrong topic, that is NOT a PC. It is an add-on module for some Panasonic TV's.
I would disconnect all power for 5 mins. Remove the module, inspect for overheated (burned,) areas, re-install and try it. Assuming you have not already done so.
Apr 21, 2014 | Panasonic TY-FB8HM - Monitor terminal...
Tip
Panasonic TY-LA1001 Lamp Replacement Manual
The Panasonic TY-LA1001 is one of the rarest enclosures in the entire DLP market to find. The same applies to the manual, so we are very proud to offer all of our visitors the replacement manual for the TY-LA1001, enjoy.
here is the link so you can download the PDF
http://www.fixyourdlp.com/2010/01/11/panasonic-ty-la1001-lamp-replacement-manual/
on Mar 24, 2010 | Televison & Video
Reset lamp meter on panasonic pt 56lcx 16
Turn on the projector MENU- OPTION- LAMP RUNTIME- Press and hold the ENTER button for 3 seconds. Turn off the power.
Dec 07, 2013 | Panasonic 2 Projector Lamp
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
I need to replace the lamp...how do i get it out?
Hi, well your TV uses the lamp enclosure TY-LA1000, here is a link where you can find the manual of how to get to the enclosure http://www.fixyourdlp.com/blog/2007/09/17/panasonic-ty-la1000-enclosure-replacement-instructions-guide/ and here is another one to replace the lamp on the enclosure http://guides.fixyourdlp.com/panasonic/TY-LA1000.php
Jun 27, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Televison & Video Logo
Top Televison & Video Experts
