Blank display only with tv mode selected. connected to digital antenna
  • 2 more comments
  • uclabruin499 Aug 30, 2010
    brand: 2005 PROVIEW model: 32" LCD TV 002-S01-RX326XU
    2005 PROVIEW 32'' LCD TV 002-S01-RX326XU
  • uclabruin499 Aug 31, 2010
    how do I set TV to receive an analog signal ?
  • uclabruin499 Sep 01, 2010
    PROVIEW 32" LCD Television RX Series , 002-S01-RX326XU
  • 17,129 Answers
Did you mean that the TV is connected to the digital box or to the DTH.
If the digital box is using the video/audio signals to connect to the AV of the TV and you are having a blank the fault can be the video/audio signal amplifiers or the A/D convertor.
Please give some more inputs to the problem.
If using an RF input , then the tuner can be defective.
Comment.
Posted on Sep 01, 2010
  • 1,606 Answers
From your description you are getting some kind of display but no picture. What you need to do is change the input source. This tells the tv where to look for a incoming signal. If it is expecting a cable signal it looks for the signal on a differant connector than the one the antenna will be connected to. You will also have to scan so the tv's senses what channels it is seeing. So set the source first if its not set to the tight one then do a scan and you should be up and running.
You haven't given make or model so generally these are found under the menu button and then setup. This is usually the first few pages of the user manual.
Posted on Aug 31, 2010
  • 11,800 Answers
Do you get something on the screen when the tv is set to receive an analogue signal - either from an antenna or from a player? If not then the tuner is faulty and must be replaced
  • Azrael SRL Aug 31, 2010
    Connect a regular antenna to the tv and go to the Programming section of the Menu and select Scan - the analogue scan will begin . If no channels are detected then you can try something else - connect an old vcr to the tv using the antenna connection (from the antenna out on the player to the antenna in on the tv) If even this way the image from the player isn't detected then the tuner is dead - replace it
    BTW this is a quite delicate job, it involves careful desoldering and soldering, if you aren't absolutely sure you can do it without damaging other components then  call someone who can.
  • 10,594 Answers
I need model number and brand info of your tv to diagnose possible cause of blank screen.
Thanks.
Posted on Aug 30, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 30, 2010
    Does tv show picture in AV input if connect a dvd player?
    Did you perform auto scan/ auto tuning so tv can scan available channels?
    yes to both questions. the picture is great from dvd and when antenna is hooked-up to other TV ( HCT TV)
    OK then on what input tv screen becomes blank?
    TV screen remains blank ( blue background ) when using TV mode ie, input directly from antenna cable.
We have an antenna, digital converter box, and digital tv. Can only get 5 channels. No nbc, abc, cbs. Get the message indicator available for digital broadcasting only
You should be able to use the box remote and select channel search mode. As it searches, you will see it "hit" available channels and store them. When channel search is finished, you should see a picture displayed. if no results, there is something wrong with the antenna, the way it is connected to the box, the way the box is connected to the TV, or the way the TV is connected to the box. You may have to reread the instructions to find what is at fault.
Sep 05, 2015 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Trying to convert from cable to antenna...I get no signal and it seemingly goes into sleep mode
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Like AntennaWeb org
Apr 08, 2015 | Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
I am having trouble recieving over the air digital signals. I have connected a 20 db amplified FM/UHF/VHF antenna to the cable/antenna coax connection, set the input to "TV", and set the TV to...
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Feb 10, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I plugged antenna in but I still can't install channels problem is that I cant choose "channels installation" option maybe because tv is on video mode but I can get it to normal mode...
Antenna?? If you connected an antenna to the TV, you can only picking up radio waves. In the TV's menu options you should have a connection selection to choose from "Cable" or "Air". With an antenna, Air needs to be selected. Go through your "Input" selector from tv remote and select "TV" which is always the first selection. If this does not help, let us know exactly what is connected to the tv whether it be a COAX cable alone, a coax connected to an antenna, or if you have rabbit ears connected.
Jun 30, 2010 | Televison & Video
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
