Question about Kenmore HE2 Plus Front Load Washer
F-01 error message on Kenmore HE2plus washer - Kenmore HE2 Plus Front Load Washer
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
We have a Kenmore HE2plus washer - about 3 years old. An error message appeared F21. The problem is that the it either seems to be stuck on the rinse cycle or isn't completing the cycle. When the...
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Kenmore washer, the F21 error means an excessive drain time as you may or may not already know.
If you follow the link to my solution to this error you should be fixed up in no time. (It's much quicker than pasting or retyping the complete solution)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance and leave a brief testimony.
Regards,
Macmarkus :)
May 07, 2011 | Washing Machines
I have a F-01 fault code on my Kenmore HE2plus front load washer. model # 11047512601. Sears talked me thru the software resets and still had the F-01 error. do I need to replace the Main Control Unit?
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
F 01 code won't come off, washer won't start
change control module remove top right front corner white or gray box
Aug 27, 2008 | Washing Machines
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
196 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
