Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Frezzer on top cold milk area will not get cold just cool cleaned evapator coils.still not cold = lot of water overflow in drain pan empty often ,modle #et20gmxfn01
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Kenmore Refrigerator by Whirlpool, model 106, top freezer. Water drips into refrigerator from freezer. I have de-iced the coils in the freezer, under a flat panel. I made sure that water flowed from the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Refrigerators
Drain Pan fills and overflows. Cannot get to drain pan to empty. Why the water and how do I get to the drain pan ? Also the refrigirator door maes a loud sound when It's opened and closed. It seems to...
The water is normal....however the evap motor and fan should be drying the water before it overflows. THe evap fan motor may need replaced. You will have to pull the unit from the wall and take the back panel off or tilt the unit back towards the wall and go in from the underneath side. As far as the door goes....you might need to tighten or replace one of the hinges.
Sep 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Water builds up and overflows on the bottom of our fridge
get into the evap. section of the unit [cooling coil] , there is a pan under it with a drain in the center , its frozen or plugged , defrost it and use a firm wire or similar to snake it out , when you get it draining in the pan again pour a cup of bleach in the evap. pan to clear mildew or whatever is in the line.
Phil
Apr 14, 2009 | Whirlpool EL7ATRRKS Refrigerator
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Oct 05, 2008 | Goodman Heating & Cooling
Ice in bottom of frost free freezer
the heaters to defrost the coil may not be working
Jun 24, 2008 | Maytag MSD2454G Side by Side Refrigerator
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Water in housing
You will need to clean the evap coil with a bleach type product and then hose out the condenser coil as well. The bleack will also remove algie from the evap water pan. THX RepairUSA
Aug 26, 2007 | Goldstar R5050 Air Conditioner
Water dripping from freezer to fridge
Sounds like the drain for the defrost cycle water may be plugged and you eventually overflow water. See if you can find the little drain hole for the coil defrost water and check for dirty/plugged. Try to pour hot water in the drain area and see if it runs out the drain fast (if real slow it's a problem). Make sure the water is also going down to the holding pan near the bottom area/compressor area (that's where it evaporates later). Let me know what you find.
Nov 28, 2006 | Kenmore 63782 / 63784 Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
