FixYa.com
Tags:
Teac SL-A100 Shelf System
Turntable plays too fast (by 2 users)
posted by kwenbogdan on May 08, 2008
The turntable plays records too fast - the record's pitch is noticeably higher than is normal.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by sylvain445, posted on Jul 24, 2008
I have a SL-A100 and I have the same problem. Actually, it's not that the turntable gets stuck on 45 rpm when I switch to 33 (which is what your solution seems to fix). It just rotates *slightly* too fast: it actually spins at 34.7 rpm instead of 33.3, enough to raise the pitch of a record just shy of one semitone. This is exceptionally annoying that a recent product like this ships with such a trivial defect.
Solution #1
posted on May 08, 2008
Not Rated (0)
marty47
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
Trouble getting ipod nano to...
New GPX Home Docking System... Answer This...
Audio Shelf Systems
Aiwa User Manual for NSX-SZ10
Where can I buy one of the... Answer This...
Audio Shelf Systems
HOME STEREO SYSTEM CD PLAYER
i have a aiwa... Answer This...
Audio Shelf Systems
aiwa nsx-v20
my cd player is acting up -... Answer This...
Audio Shelf Systems
CD continueous play
I can't get my 3 cds  to... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
