Question about Soyo TFT 19" LCD Monitor
My monitor picture will not stay on the screen until I have repeatedly turn it off and on a number of times. Once it is up it operates as normal
  • 11,361 Answers
You may have dying power supply due to bad DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 30, 2010
Please can you tell me how to increase the screen size from a normal screen to my new computer with a 22 inch
Right Click in a empty section of your desktop screen, the ox below will open and select properties gmeier.jpg
In the box that opens after properties, Select Settings (top right) and move the resolution to the right on setting and hit apply. repeat this until your happy with the screen resolution.
Hope this helps
Regards GM.
If you find this information useful please rate my response. Thank you
Apr 07, 2011 | Emprex LM2201 22" LCD Monitor
I want factory resotre so that i can use this laptop for other user
Instructional steps to follow Things You'll Need:
  • File storage device (CD, DVD or flash drive)
  • Operating system recovery disc
  1. Save the files you want to keep from your laptop's hard drive to a storage device such as a rewritable DVD or USB flash drive. Unplug any USB or Ethernet cables connected to the laptop.
  2. Insert the Windows recovery disc into your computer's optical drive. Restart the operating system.
  3. Press any key when the "Press any key to boot from CD" option appears on the screen. Use the drop-down menus to select the language and time options you want to use.
  4. Click "Next" and then choose "I accept the license agreement." Select the "Custom (Advanced)" option.
  5. Click the option for the laptop's hard drive partition and then choose "Drive Options (Advanced)." Click the "Format" link in the lower right corner.
  6. Select "OK" and wait for the hard drive to be formatted. Click the partition again and then choose "Next" to reset the laptop back to its factory settings.please leave a comment about this post by saying how helpful it is
Oct 09, 2010 | Computers & Internet
Stays on the apple screen when i turn it on
Try to reset player by holding in center and menu button together until player re-boots. If it still does not load normally, repeat this 2 button process one more time. When the APPLE logo comes back up, immediately hold center and play (bottom of clickwheel) until player enters "disk mode". You should be able to "restore" the player operating software in itunes once it is in the disk mode. If restore still does not fix the issue(s), then you have good reason to believe there is an actual hardware issue with the iPod. -your friendly neighborhood MacGenius
Dec 13, 2009 | Apple iPod nano
I turn the monitor on, then it turns itself off.
It may be the problem with the power on/off switch.The problem can be solved by replacing it.Contact you authorised technician..
Jul 01, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
Soyo TFT 19" LCD Monitor Logo
62 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
