Question about Car Audio & Video
1996 gmc suburban factory speakers
I bought the truck 3mths. ago . at first the sound started fading in and out, now it just goes out . thought it was the factory head unit so I replaced. hooked up the new unit sound came on and went out radio was crackling loudly while pushing unit into position
    Scholar:
  • 98 Answers
Sounds like you have a wiring problem.....
Posted on May 09, 2008
1996 Chevy suburban overheats now trouble starting up
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: diyobd2.fr
Apr 02, 2013 | 1996 Chevrolet Suburban
What is the popper gear to drive in when driving a 1996 GMC Suburban
Opinion based question,,Overdrive was intended to benefit larger vehicles on open road rides of distance,,uses less power to maintain steady speed, Drive was intended to be used in more urban settings, red lights pedestrians,stop and starts frequently,,more pull out power to avoid other vehicles in city setting............fuel efficency was the thought. L2 L1 pulling torque or severe condition roads only.
Jun 07, 2012 | 1996 GMC Suburban
1995 GMC K2500 Suburban, engine wont start, it will click, not a battery problem, lights, windows, windshield wipers will all work when ignition is in off position. Wouldn't start last night, fired right...
Sounds like the starter solenoid or the starter itself - probably needs replacing but check the wiring at the starter first (loose connection, frayed wires, etc.).
Oct 08, 2017 | 1995 GMC Suburban
I have a 99 GMC suburban. I just replaced the AC
Find a blue wire on the wire harness to the truck and connect from the blue white on the radio. this will turn on the factory amp that runs the rear door speakers
Feb 08, 2010 | Car Audio & Video
96 Gmc suburban wont start has to be primed
Sounds like a fuel injector is hung open.
Jan 27, 2010 | 1996 GMC Suburban
Approx.50# fuel pressure at test port, engine will only start with starting fluid and then die.
I worked on a 1999 Suburban a couple weeks ago, it had good fuel pressure and spark but wouldn't run. No check engine light. It turned out the catalytic converters were plugged. After I took the exhaust pipes loose at the manifold it started right up. Just a thought.
Jan 02, 2010 | 1999 GMC Suburban
96 GMC Suburban Started to overheat last summer.
It is probably head gaskets - These need to be replaced.
Aug 02, 2009 | 1996 GMC Suburban
Speakers don't work
you need to take out the speakers and make sure they are still hooked up.but before that try the fade and balance button.
Apr 24, 2009 | 1996 Dodge Caravan
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 08, 2009 | 1996 GMC Jimmy
Car Audio & Video Logo
214 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
