Question about Simplex Kaba Ilco Unican LP1000 Panic/Exit keyless lock
KABA Simplex 1000 Doesn't always lock - Simplex Kaba Ilco Unican LP1000 Panic/Exit keyless lock
5 Suggested Answers
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: I have a Simplex Kaba
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
I believe you can find this to be relevant:
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
What's your problem?I HAVE A LOCK THAT KEY WILL NOT LOCK ITS ALWAYS OPEN
I urge you to contact Kaba Ilco technical service and talk to a technician.
Here is the contact information:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 08, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Can a L1000 series simplex kaba be switched to mount a right handed door
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When resetting the combination for the L-1000 Simplex lever or the 1000 series knob...the lock out slide does not release after it has been pushed in....can this be fixed or is the chamber malfunctioned. I...
I can't help you directly, but I can steer you to their Tech service:
Tech Support from this link:
And Customer Service from this link:
Manuals from this site:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
The lock is staying open when the door is shuting i need to lube it but dont know how to open it up to do so
The installation instructions for simplex keyless locks can be found using this grid on the KABA website. You will need Adobe reader to view-- these are PDF files:
Dec 17, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I need a new clutch assembly for a simplex lp 1000 who do I call that has one in stock. Thanks Bruce Barrick
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex unican L1000 lock, occasionally the top two buttons do not 'connect' when pressed. Can this be remedied easily?
I need a kaba ilco spanner wrench to change the combination on a 1000 series lock. where do i get it?
Sep 21, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  LP1000 Panic/Exit keyless lock Logo
113 people viewed this question
Top Simplex Locks & Locksmithing Experts
Dwayne L brown
Dwayne L brown
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
