Question about Acer Computers & Internet
Emachines E627 Laptop I use it only in Wifi mode
Emachines E627 Laptop I use it only in Wifi mode to get on the internet. Today the wireless won't work. It only comes up in Ethernet Cable mode. I tried pushing the wireless button several times and it only displays wireless off. It won't turn it on. I tried restarting the computer several times which usually clears it and starts in wireless mode again but to no avail. I tried goiing in seven ways to sunday to troubleshoot and find a way to turn it on in the networking and device manager and could not find anything to adjust it with. The device manager just says there is an Altheros card there with options to turn it off, none to turn it on. It all goes around in circles and none of it accomplished anything with typical Windows brainiac illogic! I have had problems with it before going into Ethertnet cable mode only even though the button switch was on, but if I restarted the computer that would usually start it in wifi mode again Can anyone tell me how to get the wifi mode turned back on?
  • 2961 Answers
SOURCE: Can't turn on wifi
you should have ACER Empower installed, so check that the wireless adapter is enabled, or press F2 on start up and look in the bios for the onboard wireless adapter and see if its enabled. If non of the above make any difference look in control panel>system>device manager>hardwre tab and look down the list for an exclamation mark, if you find one then the driver for the wireless is not installed, hence showing no device. If that does not work either then there is a possibilty that the wireless card is faulty.
Posted on Sep 26, 2007
  • 1056 Answers
SOURCE: HP wireless problem
When you look at the properties for your wireless adapeter, does it say enabled?
On most laptops you'll have a key that has Fn on it. This is your function key. Hold it down, and look for a key that has what looks like a little radio transmission tower on it. Press that key (while holding the Fn key), and see if you get a pop up stating that your wireless is enabled or disabled (usually it pops up with the no symbol through it).
Try this a couple of times, with a few minutes inbetween to see if you can get it to reenable again.
Posted on Jul 31, 2008
  • 916 Answers
SOURCE: laptop got stucked up when connected thru network cable
I have had problems myself with wifi and vista causing my laptop to restart I think it's due to a recent update, try using no security on your wifi connection and see if you get the same problem. On my own laptop I had to remove the wap key and use mac address filtering instead due to this problem. Please let me know the results.
Posted on Feb 03, 2009
  • 390 Answers
SOURCE: turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
two things you may wanna check
if the wireless is enabled in your network settings
and 2nd may be there is a Fn key +some other key combination for the wireless
Posted on Jul 24, 2009
SOURCE: HP DV9000 Wireless Card Not Working
this is not a solution, but it isn't helpless info either like "push the button all the way".. the thing with our laptops (dv9000) it's that our chipset, nVidia, it is often too hot for the motherboard, that makes something melt in it or something and stop working, unless you can get it fixed before everything else stop working you should get that fixed PRONTO. it's around $150,00 or call tech support cause i was told that some of this problems are being fixed by HP dependig on the purchase date .. right now i'm using a wireless internet d-link pendrive. try to get that fixed cause next thing it's going to stop working it's goig to be the entire motherboard.. and we don't want that to happen.. right?
Posted on Aug 31, 2009
Emachine e627 won't bootup
You're probably going to have to get someone to physically look at this for you. eMachines are notorious for having trouble sometimes. However, since you haven't described exactly what it DOES and DOES NOT do, it's hard to tell. Good luck! :)
Jan 14, 2013 | eMachines E Machines E627 Laptop Computers
My emachines e627 laptop wont burn cd
Test burned CD in another drive after burning. I had a drive that did that just before dying. Also make sure the software if not set to test (simulate) only. gl
Jan 10, 2013 | eMachines E Machines E627 Laptop Computers
Emachines t3418 no wifi connection
do you have wifi adapter (wifi dongle/wifi modem) in your computer if no you have to buy it
Jul 16, 2017 | Computers & Internet
Emachines E627 laptop won't turn on, but the power button is blue.
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Oct 28, 2011 | eMachines eM250-1915 Netbook
I can not get on to the internet at home i have a wireless connection and it was al working fine up untill i wiped my computer clean and reinstalled windows 7 could you please help me my connection is fine...
Since you re-programmed your laptop, you need to install the driver for wireless LAN. You mentioned that you're using Win 7 now so you need to find a driver that is compatible with emachines and Win 7. But you can try to download the driver fromm emachines' website:
Hope it helps.
Feb 07, 2011 | Computers & Internet
I Have an Emachine E627 Laptop and I'd like to use my webcam
I have an emachines e627 and it has a webcam, because there are different models of the emachines e627. Most likely you have an emachines e627-5583, that model has a webcam. If you are trying to use your webcam there is a program that is built in called just go to "C:\Windows\Video Web Camera.exe". I hope this works for you
Dec 29, 2009 | Acer eMachines 520-2890 Notebook
Computers & Internet Logo
1,631 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
