Question about JVC KD-R900 Car CD/ MP3 Player
I have a new JVC kd-r900. What would cause it not to power on when wired to correct 12v power? I get three lights on the right of the faceplate, but nothing on the left or display. All the contacts are clean (new). Both red and yellow are connected to 12v power, and it is grounded. Thanks for your help in advance.
informatica
  • 1114 Answers
SOURCE: JVC KD-G430 problem setting the time
You can download the manual from the link below: http://books.jvcservice.com/booklist.asp?Model=KD-G430 The time setting is on page 13. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 21, 2007
SOURCE: Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
Posted on Jul 09, 2008
bigTROY502
  • 129 Answers
SOURCE: i need to replace my faceplate only because someone stole it
www.pacparts.com
Posted on Aug 11, 2009
  • 31 Answers
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
  • 31 Answers
SOURCE: Installing KD-HDR20 and I get a red power light but nothing works
I have had the same issue and I tried until I found the problem.
1) I had no power to my remote wire.
(The wire that only allows the radio to work when the care ignition is on.)
2) The radio has a fuse or maybe two.
But the auto mobile may have blown its fuse.
In my case it was the remote fuse.
3) I have had a bad ground and only need to find a good place.
4) I have even found insufficient power to my radio because too many devices were also using that power.
5) Heck I have even forgot to start the care or at least turn the ignition.
6) My battery was so dead it couldnt even power my radio.
Posted on Mar 16, 2010
Jvc kd avx33 faceplate power light comes on. i hit power button it lights up blue then nothing it beeps then i hit the power button though.
Problem with KD-R200 or KD-AVX33?
What does it mean by "it lights up blue then nothing?" Does it takes CD in?
Oct 26, 2013 | JVC KD-R200 Car CD/ MP3 Player
Replacement faceplate for a jvc kdhdr50
Are there other faceplates that are compatible with my jvc kd-hdr50 because someone stole mine and i cant find anywere that sells just faceplates
Jun 27, 2012 | JVC KD-HDR50 Car CD/ MP3 Player
My jvc kd-r418 is protect
that happened to me too once, in my case it turns that one of my speaker wires came loose from back of speaker and was touching the metal in my truck. after correcting the wires it still said protect, i then found the reset button located under faceplate and held it down for a few seconds and my receiver was back in business.
Oct 01, 2011 | JVC Kd-r418 Car CD / USB/ MP3 Player
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
My KD-LH810 turns on and plays the cd that is in it but the faceplate does not come on and it continues to play the cd - I cant turn it on or off and none of the other buttons work on the faceplate work so...
wipe the connection where the face connects at i had the same problem and it works fine after cleaning the connection and i will guess the power light itself is still lights up and no other button lights or the screen itself if that is correct then u most likely just have moisture in the connections try wiping it with a dry soft cloth
Oct 27, 2010 | JVC KD-LH810 CD Player
I hooked up my JVC KD-R200 to a 1991 Toyota Tercel and I can't get the face of the stereo to turn on. No sound, no radio stations, just the lights around and on the buttons come on. I have another stereo...
try reversing your red (accessory) and yellow (constant) wire... also check the fuse on the back of the radio. and it wouldn't hurt to clean the connector between the faceplate and the radio either corrosion can cause this....
May 01, 2010 | JVC KD-R200 Car CD/ MP3 Player
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
I have a JVC KD SH55 and won't eject CD. Fix please. Recall?
there is a ribbon wire that connects the faceplate contacts behind the faceplate that always go bad on all radios with rotating faceplates. you can probably find this part on ebay or on parts.com or by jvc.
Sep 08, 2009 | JVC KD-SH55 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
JVC KD-R900 Car CD/ MP3 Player Logo
54 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
