Question about Acer AL1914 19" LCD Monitor
Screen Display When i power on my monitor it flashes and then turns black again and it continues to do so. As if there is a problem with the power. Is there something that might fix this?
  • raymondmtg Sep 01, 2008
    When I moved my mouse the screen appeared as usual and then it faded to black and made an audible pop about every 4-5 seconds.
  • lmlarson3 Sep 04, 2008
    AN1914 Acer is not a digital monitor. Also we can no get to the source screen as it is flashing on and off. Do you or anyone else have a solution? Other then placing a small charge on it and watching it explode?
Some monitors have multiple settings. For example, mine has digital and anolog setting. If it is on digital, it will do exactly the problem you are saying, try finding a button on the monitor called source, or something along those lines.
Posted on May 08, 2008
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
I have SyncMaster 2233BW with a screen problem. Once I turned it on it will flashes display then in a second or two the screen will turns black. Press power button again it will comes on then turns black...
did you check the output dc voltage at the power supply board if stable. if ok tried to disconnect first the supply going to the power inverter board of screen back light just to ensure if not the cause of shut down.
Oct 15, 2012 | Samsung SyncMaster 2233BW 22" LCD Monitor
My laptop hp have problem monitor giving mesage ''monitor going to sleep''
hi you will need to reinstall the vga of the system to enable it not to write that again
May 19, 2010 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Acer AL1914 19" LCD Monitor Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
