Question about Sony PlayStation 2 Slimline Console
When i put a disk in to my Slim PS2 it says 'reading disk' but then never goes on to the game and just goes back to the main menu. What can i do to fix it?
  • 277 Answers
HI,you’re going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you’ll be familiar with the entire process. First take off the outer cover of you PS2. If you haven’t done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover. {mos_sb_discuss:18}
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I’ve seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you’ve toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you’re finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you’ve found the proper angle and the system is operating to its full potential, close it up and let’er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
Posted on Aug 30, 2010
PS2 Slim trouble reading disks
take it to a game shop for a lazer service take the problem discs with it,its the best way
Jul 16, 2010 | Sony PlayStation 2 Slimline Console
Slim PS2 can't read some games
please make sure that the disk is readable
please look for the recognized formats in the manual
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
My playstation wont read any of my gaming disks i
Have you tried a lens cleaner kit?
This is the CD-ROM with a small brush on it to clean your laser lens head.
This problem has happened to me in the past and this solved the problem.
It is a common problem for any lens reading console.
Regards
Aug 02, 2009 | Sony PlayStation 2 Slimline Console
I cannot play my dvd game on my ps2 , but my friends can play my dvd game on his ps2
Fat and Slim PS2's generally have different playability with disks. a slim, for example, does not want to play old blue-backed disks, though it will easily read PSX black backs. I'll need more information on the disk and the PS2 to give a complete answer.
Jun 11, 2009 | Sony PlayStation 2 (PS2) Console
We just purchased Guitar Hero and when we put it in our PS2 it dont spin the disk??
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
A heavy object fell on my ps2 slim line and now it can't read games but reads dvd movies
sounds like it bumped the laser alignment out of wack do a google search for ps2 slim laser alignment howto and it should bring up the steps you need
thats the ps2 fat video below but will tell you the steps required
Oct 03, 2008 | Sony PlayStation 2 (PS2) Console
CANNOT READ DISK
the ps2 console have all been acting up. my solution is to go out and get an upgrade (ps3)
Jul 18, 2008 | Sony PlayStation 2 (PS2) Console
Slim ps2 disk read error
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
Jun 26, 2008 | Sony PlayStation 2 (PS2) Console
Problem with my slim playstation
Replace your laser is a common problem for ps2.They have alot issue about readung disk and if you have aold ps2 try to adjust the lens.Look also for ps2 repair tutorial.
Good luck
May 22, 2008 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
